Running speaker wires question?
Old Oct 31, 2009 | 01:37 PM
ydlee's Avatar
ydlee
Default Running speaker wires question?
I have a 04 with bose system and I want to upgrad to the following:
head unit
front and rear speakers
Sub in stock location
5 channel amp
My question is on running the speaker wires, if I can run them to the stock bose amp cut it off there by connecting them there? So basically let the new wires run up to the stock wires at the location of the factory amp. Or the easiest run new wires from new amp behind to the HU wires? Saves me the trouble of running wires through out the whole car since it is already ran. I know the watts will not be efficient.
Old Oct 31, 2009 | 02:28 PM
hellsoldiers08's Avatar
hellsoldiers08
Do it, do it right the first time.
Old Oct 31, 2009 | 06:41 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
No, I'd recommend against it.
The wires from your headend go back to the "amplifiers" and then from them to the speakers so you'd have to trace the wires back to the amps and then bypass them. I did this for about two weeks while I was awaiting my amps to arrive from a mail order. You'll then have to splice the factory speaker connectors to the aftermarket ones ... you've got two splices in a line that now can go bad on you ... and double your labor effort. Once you've pulled the interior apart to get to the rear speakers you're not going to want to do that again.
It's a pain but run the wires around the factory ones. The toughest part will be getting into the front doors though the rubber boots but it can be done.
Here's the ball of wire you end up with to by-pass the rear amplifier ... that's a lot of soldier and heat shrink.
Old Oct 31, 2009 | 07:11 PM
*ICE*'s Avatar
*ICE*
sub will sound like crap in the stock sub position. It will rattle like crazy. Get a custom box made or get one online for cheap.
Old Nov 1, 2009 | 09:31 AM
ydlee's Avatar
ydlee
So there are only two factory amps one for the mids and one for the sub correct? Where is the factory amp for the mids located? I found the sub one and was thinking of taking the whole factory plate of the bose sub and mount a bass tube pointing out the bose cover.
Old Nov 1, 2009 | 02:42 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The mid/tweet amplifier is mounted under the antenna in the back driver's side quarter panel.
aarrgghh
May 1, 2022 11:04 AM
bcoffee20
Nov 19, 2015 06:39 PM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
