Emergency Fuse Panel Question
Old Dec 23, 2009 | 01:12 PM
xthejokerx's Avatar
xthejokerx
Default Emergency Fuse Panel Question
Hi guys, I want to know which fuse is for the headlights?
This is the diagram for the fuse panel located above the dead pedal. Thanks
Old Dec 23, 2009 | 05:44 PM
xthejokerx's Avatar
xthejokerx
Hey guys, I found out that the headlights fuse was in the engine bay....
If I'm looking to install the Prosport gauge, which fuse from the headlight do I use, assuming I'm using add-a-fuse?
Old Dec 27, 2009 | 03:19 PM
KPierson's Avatar
KPierson
You can't use a fuse - the fuse is BEFORE the relay that turns on the headlights. If you tap in to it it will be hot at all times (even with the key off).
You need to tap in to the headlight wire AFTER the relay, which is in the IPDM. If it were me, I would tap in to a parking light wire in the drivers kick panel - much easier then running a wire and making a splice under the hood and basically the same effect.
3vilbunny
Jul 18, 2017 05:10 PM
