CDA-105 Rear iPod Input Placement
Old Dec 26, 2009 | 05:29 PM
2ndname's Avatar
2ndname
Default CDA-105 Rear iPod Input Placement
Hello all,
I have just installed an Alpine CDA-105 on my 2003 Z with stock sound system.
My g/f bought the HU from Crutchfield so it came with the DIN and harness kit.
Everything is installed just fine but I left the iPod rear input cable behind the dash.
My question is, is there a nice way to go about getting this cable out to the front? Not sure if I should cut a hole on the lower DIN pocket and just have the cable dangle and coiled in there or what.
Also, another thing that I was thinking about, should I just cut the wires and tape off the rear speaker wiring? I only run the front speakers and was wondering if it makes any difference for me to just push everything to the front versus push everything to the front + not connecting the rear wiring.
Old Dec 26, 2009 | 07:00 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Why on Earth would you not hook up the rear wires. It's just a matter of connecting the supplied harnesses correctly. There's no "running of wires" unless you're installing new speakers/wiring.
Follow the directions and connect the harnesses.
I don't know how long your iPod wire is, but I ran mine through the center console and into the storage bin between the seats.
Old Dec 26, 2009 | 07:25 PM
2ndname's Avatar
2ndname
The rear wires are hooked up right now but since I push all of the audio out to the front speakers, I was just wondering if it is better to just disconnect the rear wiring/harness altogether.
The cable that I got is pretty long so the storage bin idea might work actually.
Did you have to drill a hole or anything? Any pictures of your storage bin with the wire out?
Old Dec 26, 2009 | 07:29 PM
TreeFiddyZee
Do WHAAAAT!?
I cut a small hole at the bottom-front of the storage bin. No pics. I traded the car last month.
I had to pull out the console to run the wire. There is a screw below the coin box, a couple below the HU and two at the back of the console (you have to move the seats up to see them.
Old Dec 27, 2009 | 04:51 AM
2ndname's Avatar
2ndname
Got it. Thank you!
Depravity
Oct 1, 2015 04:49 PM
