Multiple monitors with Mini-PC, how do you do it?
Old Oct 21, 2003 | 12:40 PM
Mikestro's Avatar
Mikestro
Default Multiple monitors with Mini-PC, how do you do it?
I would like to know how to hook up two monitors (with no VGA inputs) like the 3X5" Xenarc monitors to an in car PC. Is there a video hub of some sort available?
Thanks,
Mike <----video newb
Old Oct 21, 2003 | 02:58 PM
ares's Avatar
ares
Veteran
you can buy AV cable splitters.
obviously youd need AV outs on your video card to play to a AV monitor, but you can just split it, youd find it in your TV section of bestbuy or whatever, not with the computers.
Old Oct 21, 2003 | 03:06 PM
Mikestro's Avatar
Mikestro
if you split it, wouldn't each signal be at 50% magnitude? Is that still high enough signal to drive two monitors? What if I wanted to split to 4 or 8 (just out of curiousity) do they make active splitters that would split and amplify as well?
Old Oct 21, 2003 | 03:13 PM
alphared's Avatar
alphared
If your pc don't have S-Video out or just VGA, you'll need a VGA-Svideo (or RCA) converter. Depending on distance, you'll need a video booster. 4 monitors or more you'll need it.
Video booster
The converter will run you about 50 bux. You'll have to tap into the car's battery to power the booster.
Old Oct 21, 2003 | 03:33 PM
Mikestro's Avatar
Mikestro
thanks for the help everyone, this clears things up.
416blueZ
Jun 11, 2024 10:56 AM
apex locator
Jul 23, 2021 02:27 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
416blueZ
Sep 24, 2015 02:11 PM
