BOSE Wiring
Old Jan 21, 2010 | 10:43 AM
dcash5's Avatar
dcash5
Default BOSE Wiring
Hello
I have searched, Does anyone know if the bose headunit lighting and the Bose power is fed seperately
At the moment it appears like im not getting any power to my HU but when I turn the car headlights on the stereo buttons light up (Bose Screen doesn't though!)
Can anyone shed any light (or possibly power ) on this for me please?
Cheers
Dan
Old Jan 23, 2010 | 05:52 AM
dcash5's Avatar
dcash5
As none of you buggers knew, I'd thought I'd answer my own questions ..
Dan - Yes you are correct the bose is fed by two power sources so you will see the button illuminate with the headlights
Old Jan 23, 2010 | 05:54 AM
dcash5's Avatar
dcash5
Dan have you tried checking the grounding points through the screws underneath the aircon controller box - it may be a poor ground?
Guessing you have checked the fuses and connections etc?
Old Jan 23, 2010 | 05:56 AM
dcash5's Avatar
dcash5
Ah thanks for your help Dan you were right the grounding points on the four bolt were at fault. I found this out by unscrewing with the ignition on!
Thanks mate you are the most knowledgable bloke on this forum!
Old Jan 23, 2010 | 09:40 AM
NttnbutaZthang's Avatar
NttnbutaZthang
this sucks
m_0g
Jun 3, 2021 10:05 AM
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
