Bad Radio Signal
I just purchased a 350Z. Everything on the car is stock. Its the touring, with Bose stereo. All the channels (except one or two) come in fuzzy. It appears to have the stock antenna. What are some tips or areas I should look to fix this problem?
Thanks.
Thanks.
warp the antenna in aluminum foil. You will picking signal all the way from Mars.
on the serious note, is this the stock antenna you got?
you can remove the center console, look at the back of the radio, and see if the antenna wire is unplug or loose. Make sure its plug in tightly. All else fail, take it to the dealership.
Alright I will try. And yes it is. the rubber around the base of the antenna is beginning to crack, but I am weary to think it is the cause of the bad reception.
Thank you.
Thank you.
