signal source question?
Old Mar 6, 2010 | 01:50 PM
yankeefanzh's Avatar
yankeefanzh
Default signal source question?
Hey guys Im adding an amp to the factory bose system in my 03 Z. Would there be anything wrong with tapping into the harness before the rear amp for my rca converter instead of the HU harness? I dont see a problem but maybe someone might have more info for me my thinking is i wouldn't have to tear the dash apart and it would be less of a distance for my rca cables. thanks for the help!
Old Mar 6, 2010 | 05:46 PM
Welcome. You are tapping into this line for 12v DC power? A simple diagram might be helpful?
Old Mar 6, 2010 | 08:27 PM
yankeefanzh
no no i already have the power cable ran from the battery to the back of the car i am wondering about the adapter for the actual sound signal if i can just splice into the harness before the rear amp or if i need to splice in behind the headunit?
Old Mar 7, 2010 | 01:32 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
It will work but ... replacing the cables that run back through the cabin with better ones can only help. I would suspect the quality of the stock cables.
Old Mar 7, 2010 | 07:46 PM
yankeefanzh
ok ill do that then thanks alot!
lapham3
Oct 7, 2022 03:15 PM
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
