help on sub wiring
Old Mar 9, 2010 | 02:23 PM
bbak11010's Avatar
bbak11010
Default help on sub wiring
hey all, just a quick question for wiring the subs.
I have two 10" Image Dynamics ID10V3D4 trying to connect to
Image dynamics Q600.1 mono amplifier.
I purchased these from Woofersetc and the guy told me to wire it this way.
I just want to check if this is a right way to wire them.
Any help is appreciated, and sorry for the crappy drawing.
Old Mar 9, 2010 | 02:54 PM
Z1NONLY's Avatar
Z1NONLY
^^^No.
Your pic would only make one coil on one sub operate.
I just googled your amp and found this....
http://www.imagedynamicsusa.com/pdf/...al%20Q-amp.pdf
It says your amp is stable into 1 ohm. I had less luck googling your subs but the part number seems to indicate dual 4 ohm voice coils on each.
If this is correct, all you need to do is connect each + terminal on ech voice coil to the + speaker output on your amp. Then connect each - terminal on each voice coil to the - speker terminal on your amp.
If your subs have dual 4 ohm coils, this will create a 1 ohm load.
I am on my way out the door, or I would draw a pic for you, but for now that's the best I can do.
If any of my assumptions for your equipment are incorrect, disregard my post. For instance, if your subs have dual 2 ohm coils, this could fry your amp.
Hope this helps.
Old Mar 9, 2010 | 03:01 PM
KPierson's Avatar
KPierson
If they are single coil subs then the picture will work.
If they are dual coil subs the picture will not work.
I did a quick search for the model number but didn't see any relevent specs. Can you provide more information as to the impedence or number of coils per sub?
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
