2007 350z Neutral Safety Switch
Old May 15, 2010 | 03:27 PM
ATL_Red_G35's Avatar
ATL_Red_G35
Default 2007 350z Neutral Safety Switch
Does anyone know where I can find the Neutral Safety Switch wire and tap into it to install the remote start on my car?
Thanks.
I've been told it's PIN109 off the ECU and wondering how can I locate it since the ECU has 3 separate part and I can't tell which pin is which number.
Also, is there an alternative location for that wire?
Thanks again.
Old May 15, 2010 | 04:25 PM
DavesZ#3's Avatar
DavesZ#3
I'd suggest finding a copy of the service manual for your model year. That's the only way to know for sure.
Old May 15, 2010 | 04:44 PM
fakejojo's Avatar
fakejojo
The neutra safety switch is located above the clutch pedal, you will see a black pressure activated switch that is near part of the clutch pedal
Old May 15, 2010 | 05:17 PM
DavesZ#3's Avatar
DavesZ#3
I don't think that's the one he's looking for. Manual and Auto trans have a switch that indicate when the car is in neutral. Since he's installing a remote start, it make sense that you don't want the car starting if it's in gear.
There is problably an override to handle the clutch switch for MT cars.
Old May 16, 2010 | 07:40 PM
jonny_q's Avatar
jonny_q
if it is a viper/clifford starter your putting in check the wiring diagram. a lot of the time u can just use the e-brake and as the driver just make sure the car stays in neutral. with a proper manual remote starter it will have to stay running until you are out of the car anyways to ensure it is really in neutral
etkms
Jun 19, 2022 06:30 PM
SanmarinoZ
Oct 21, 2015 10:04 AM
bryanlam199
Sep 24, 2015 04:04 PM
Upstreammiami
Sep 17, 2015 02:45 AM
issyz
Sep 12, 2015 04:18 PM
