My door and A-pillar pod fabrication *pics*
Old Jun 20, 2010 | 10:44 PM
orgasm_donor's Avatar
orgasm_donor
Default My door and A-pillar pod fabrication *pics*
I was getting a bit off topic with my other thread so I decided to post a new one with just my door pods and my A-pillar pod fabrication.
For my A-pillars I started off with a couple of 3/4" rings that were router out to fit my new DD tweeters. Not sure what happened to the pics of these rings but here they are attached to the A-pillar, stretched with grille cloth materiarl and fibreglass reinforced. I used a "Laser Beam" (insert Dr. Evil voice here) to get a perfect trajectory from my tweeter to my ear. They are within 3% of axis to my ears:
Yes, at first they look nasty but after some sanding and some 'massaging' they started to look like they should:
So after getting the basic shape and structure, I was able to use some Icing body filler to get a much more refined shape to them
After many hours of sanding I got the shape I wanted. The only part I did not do was the vinyl work and stitching. My buddy Lowell does that for me!
Now for the Door pods. I started by removing the factory speaker grille and inserting a piece of 6.5" PVC pipe into the hole. I traced out the angle of the door panel then cut the pipe down to size. I used a 1/4" piece of ABS plastic as the backplate and CA glued them together (not shown).
I taped all around the pipe and got my fibreglass and resin ready
Small pieces of 1 oz matt were perfect for getting around all the corners
A great source of vitamin 'I'm going to die!'. I wore a respirator during all of the other glassing...lol
Lookin' toight! All trimmed up and ready for part deux. These pods were designed to be completely removeable from the door panel if need be.
Routered out my rings
Got ma stilts on
Speaker clearance test fit
Stapling the fleece
Resin time!
After about three layers of glass it was time to smooth them all out using some Icing (lightweight body filler)
Lots of 1 oz glass inside
Another test fit before the vinyl wrap
And another call goes to Lowell, my vinyl buddy. He does great work!
There you have it! Feel free to ask me any details of the build. I did all of what you see here except the vinyl work.
Old Jun 20, 2010 | 11:46 PM
sdZ33's Avatar
sdZ33
Great Job!... Your buddy does nice stitching as well... If you would be able to make another identical set I would pay for it!... Please PM me if we can work something out...
Old Jun 21, 2010 | 01:22 AM
duro78's Avatar
duro78
Niceeeeee !
Old Jun 21, 2010 | 03:26 AM
SamSpicer's Avatar
SamSpicer
Looks good!
Old Jun 21, 2010 | 05:07 AM
glenns280's Avatar
glenns280
nice job +1 on the stitching
Old Jun 21, 2010 | 05:45 AM
dkmesa350z's Avatar
dkmesa350z
Amazing work. I wish I had the time and patience to learn to glass. How much did you pay to have the pods wrapped?
Old Jun 21, 2010 | 08:58 AM
orgasm_donor
I installed a deck and two speakers for him if I remember correctly (his own).
Old Jun 21, 2010 | 09:03 AM
blueVQ's Avatar
blueVQ
is the speaker close to your leg when you are in the car?
Old Jun 21, 2010 | 09:20 AM
ELI350Z's Avatar
ELI350Z
great hands man!!
wish i could do half of that..
Old Jun 21, 2010 | 06:31 PM
revvenue's Avatar
revvenue
As I said before... both v. hot man! Awesome work you do, makes the Z proud.
Old Jun 21, 2010 | 06:42 PM
*ICE*'s Avatar
*ICE*
where will the passenger put their drinks now???? jk. very nice outcome indeed!
Old Jun 21, 2010 | 06:55 PM
orgasm_donor
The speaker does stick out futher than the stock door panel (of course) but its really not a big deal for me. It kind of creeps me out when I turn it up and the midbass 'air' slaps my knee.
The car is an '03 so no drink holders in the door panels anyway.
Old Jun 21, 2010 | 06:58 PM
kacz07's Avatar
kacz07
Damn. Nice work, man. Wish I had the time and resources to do that.
Old Jun 21, 2010 | 07:01 PM
dkmesa350z's Avatar
dkmesa350z
wells that's a sweet deal!
Old Jun 21, 2010 | 07:03 PM
Flee0588's Avatar
Flee0588
tight
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
Mikey R6
Sep 19, 2015 01:48 AM
roadmax
Sep 12, 2015 05:55 PM
AP350z223
Sep 8, 2015 04:38 PM
