Rockford Amp + Jackhammer Subs = BOOM?
Hey guys, lst thread Im going to make about this, promise. lol
I just had a question... Im going to pickup a 1200 Watt Rockford Fosgate amp from a guy on craigslist tomorrow for $80. (he said the model is possibly a 301 or a 401?) I figured its not a bad deal. But main question is...
Will this 2 channel amp be good enough to support my 2 10'' MTX Jackhammer subs (rated at 4 ohms each)? I just dont wanna waste my money...
You can bridge the RF 301 for 300W RMS @ 4ohms. Keep in mind RF always underrates their amps and on the older ones they could be closer to 500W RMS.
For those speakers you have to come to a decision if this is going to be enough power to make them thump... 500W RMS on the top-end (not max wattage... much different) or 300W RMS on the low end.
Imo you should buy a mono amp and wire those subs down to 1 ohm it makes a lot more sense. You would be maximizing the power and it will be more efficient. I wouldnt bother with that amp plus if you upgrade down the road you woudlnt have to buy another amp
get a mono amp, as Duro78 said.
I just picked up 2000w mono amp, for my 2 10" Alpine Type-R's, for a little over $100, new-in-box. The amp is rated at 1200w RMS at 2 ohms, which is what the subs are rated at.
Agreed, running subs with a class a/b amp is a waste of good current that can be used elsewhere in the overhead of your audio system. This is assuming the amp you are buying is the Punch 301S.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
Tochigi_236
Sep 27, 2015 03:40 PM
1200w, 24, 350z, 401s, alpine, amp, craigslist, fosgate, good, jackhammer, jackhammers, punch, rockford, subs, videos
