Car Alarm Help
Old Jul 5, 2010 | 08:40 AM
hearts98jm's Avatar
hearts98jm
Default Car Alarm Help
Viper vs Python?
Also does anyone know of any good places they would recommend in the gaithersburg-rockville area for installation?
Old Jul 5, 2010 | 03:10 PM
revho's Avatar
revho
Viper and Python are the exact same thing they are both made by DEI. Are you looking for just an alarm or an alarm remote start?
Old Jul 5, 2010 | 04:05 PM
hearts98jm's Avatar
hearts98jm
Yeah after doing alot of research I realized they are the same. Do you know any good places to recommend for installation in the gaithersburg-rockville area? Also, what are your thoughts on Best Buy installation?
I just want a good alarm with shock sensor, if it comes with remote start then so be it, but I am really not interested in the remote start, I am more interested in the sensitivity of the alarm - touch it goes off!
Thank you for your help!
Old Jul 5, 2010 | 04:21 PM
Entaille's Avatar
Entaille
clifford, python, viper.. it's all the same.
best buy install .. no thanks! there has to be a higher quality shop in your area. sorry I cannot suggest one.
Old Jul 5, 2010 | 04:24 PM
hearts98jm's Avatar
hearts98jm
Can you recommend which version of the viper or any other? Yeah I would rather not best buy, hopefully someone will know a good shop in the area.
Old Jul 5, 2010 | 04:37 PM
revho's Avatar
revho
I know a few Best Buy installers and they are very good and MECP certified, but at the same time there are Best Buy installers that are not very good at all. Its a crap shoot. Its not all about the place you go because most shops will have good installers and bad ones. If did go with Best Buy though you know that they are a big company and will take care of you if something did go wrong. i guess they also warranty the install for the life of the vehicle. From the installers I know from there Best Buy has very high standards for their alarm remote start installs. They don't use T taps or Scotch Locks either like some mom and pop shops do. I would search around install bays in you area and ask them what kind of connection they use when installing alarms and how long they have been installing for. If you do go to best buy see if the installer is MECP advanced certified because if he is that should mean he knows his stuff and has probably been installing for awhile.
If you really want a sensitive alarm you might want to also invest in a motion sensor. They can become annoying though. Most of the alarms have the same shock sensor its more about the features you want, as in 2 way feature and how many aux outputs you want.
Old Jul 5, 2010 | 04:40 PM
hearts98jm's Avatar
hearts98jm
Thats great advice. I will check the best buys around here and see if they are MECP advanced certified. Someone else mentioned to me that same thing that Best Buy will be here in a year if something happens, but who knows with these small shops, they come and go so fast. Do you know any installers that work for Best Buy in MD?
Old Jul 5, 2010 | 04:43 PM
hearts98jm's Avatar
hearts98jm
What kind of connection for install am I looking for them to say? Also which Viper alarm has the best sensitivity? I want it to be if they touch it goes off, even touch my rim!
Old Jul 5, 2010 | 05:22 PM
revho's Avatar
revho
No I dont know any installers in MD sorry. Shock sensors are really not that sensitive to where if you touch the car it will go off. if they did make them that sensitive they would be going off every time it rained. Thats why i suggested the motion sensor that way if they walk too close to your car it will warn away ,and if they try to touch your window to look in or something like that it will go off.
The best connection would be when they strip back the insulation on the wire in the car the poke a hole through the wire in the car the stick the wire to be connected through the hole wrap the wire around the factory wire then solder, tape then zip tie the connection to stop any stress on the connection. I know Best Buy does it that way but doesn't solder because it makes it easier to remove when the customer wants to alarm removed. Personally i don't think the solder is necessary if you do all the other thing I mentioned. But I have seen a lot of mom and pop shops use T tap and Scotch Locks, i think those are horrible connections. the reason they use them are because they are fast.
Old Jul 5, 2010 | 05:49 PM
hearts98jm's Avatar
hearts98jm
Thank you for all the detailed help Revho. Can you suggest some alarms with good sensors?
Old Jul 5, 2010 | 06:08 PM
hotshot350's Avatar
hotshot350
I just got the viper 5901 with the additional radar sensor. I love this system. I turned the sensitivity all the way up and rain and anything that walks like 2 feet from my z would set the alarm off
Old Jul 5, 2010 | 06:12 PM
revho's Avatar
revho
I have mostly only dealt with DEI alarms their shock sensors seem to be just fine. There are other sensors available like tilt sensor, glass braking sensor, and motion sensor.
Old Jul 5, 2010 | 06:15 PM
hearts98jm's Avatar
hearts98jm
Thats sweet! Sensitivity is great, but what about at work when your parking in the parking lot. So anyone that parks and walks next to your car it goes off? Also does it have a shock or tilt sensor?
Old Jul 5, 2010 | 06:22 PM
hearts98jm's Avatar
hearts98jm
Also where did you get the viper installed?
Old Jul 5, 2010 | 06:31 PM
revho's Avatar
revho
Thats the same alarm/remote start I have. Its a sweet *** alarm!!! You can also get an adapter put on so you can control it and receive alerts through an Iphone or blackberry
Old Jul 5, 2010 | 09:43 PM
hotshot350's Avatar
hotshot350
you will be fine with just the radar sensor. you just have to play with the sensitivity to what you like. If you really need the sensitivity up that much you better park far away from everyone else. because they will set it off just by opening there car door. And I got it installed at a specialty shop that only installs alarms n systems, so look for one around you
Old Jul 6, 2010 | 05:09 AM
hearts98jm's Avatar
hearts98jm
so is the viper 5901 to much for wht i need? also what actions trigger the radar sensor? touch, vibration? also the radar sensor doesnt have the 2 feet sensor thing right? thanks again for ur help!!
Old Jul 6, 2010 | 01:54 PM
hotshot350's Avatar
hotshot350
IMO get the 5901. The radar sensor has the two feet motion detection around your car but thats with the sensitivity all the way up.
Old Jul 6, 2010 | 06:45 PM
zaperroni's Avatar
zaperroni
i'm happy with the functions and ease of use with my viper 5901
Old Jul 7, 2010 | 08:27 PM
hearts98jm's Avatar
hearts98jm
Thank you all for your help and input.
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
kyin
Sep 29, 2015 06:57 AM
