Stock Sub Wiring Troubles
Old Jul 20, 2010 | 09:28 AM
KawasakiMike9's Avatar
KawasakiMike9
Default Stock Sub Wiring Troubles
Recently the stock BOSE sub behind the driver's seat has been going on and off while driving if I hit a small bump or something. Has anyone else had any troubles with this, and if not what wiring should I look at to fix the problem. I tried searching for this same problem, but everything I found was about aftermarket audio setups
Thanks
Old Jul 20, 2010 | 09:30 AM
blasian's Avatar
blasian
https://my350z.com/forum/audio-and-v...-drop-out.html
It's the sub amp more than likely.
Old Jul 20, 2010 | 12:50 PM
exZilaration's Avatar
exZilaration
I posted something like this a while ago. Figured out the problem. Its the square gray relay in the amp thats not making proper contact with the metal. Open it up and but something like a piece of rubber in between the cover and the relay to put pressure.
Old Jul 20, 2010 | 01:16 PM
KawasakiMike9
Thanks for the help guys. How do I really go about getting to the sub? Do I just pop out the cover? ... I don't want to break anything so I thought I'd make sure first.
Old Jul 20, 2010 | 01:19 PM
richcity's Avatar
richcity
http://www.350zmotoring.com/forums/3...tting-out.html
Old Jul 20, 2010 | 04:14 PM
exZilaration
^ There you go
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
