Equalizer channel question
Old Aug 24, 2010 | 02:05 AM
Ziggyrama's Avatar
Ziggyrama
Default Equalizer channel question
Hey guys, I am considering adding an equalizer to my audio system to gain better control over the sound. I have seen several equalizers out there that offer only 2 channel RCA inputs while providing 5 channel outputs, like this one:
http://www.hifisoundconnection.com/S...5410/SFV/30046
My question is, how would I hook this up? Currently, I have 5 channels running from my HU to my speaker amp and the sub amp. Am I missing something here?
If the above unit isn't a very good one, feel free to suggest something better. What I am looking for is a decent unit that will allow me to fine tune the bands without breaking the bank. I would likely mount the EQ out of site, not on the dash.
Old Aug 24, 2010 | 02:14 AM
Ziggyrama's Avatar
Ziggyrama
This seems like a nice unit:
http://www.crutchfield.com/s_161EQSG...ay.html?tp=116
What do you guys think?
Old Aug 24, 2010 | 06:56 AM
The equalizer is designed to be installed "before" the power amplifier.
Old Aug 24, 2010 | 07:48 AM
Ziggyrama's Avatar
Ziggyrama
Yes, I get that point. A typical HU will have 5 channels running out of it to the amplifiers: 2 for the fronts, 2 for the rears and 1 for the sub. So, given that, how am I supposed to connect 5 signals into a single EQ which will then feed the altered signal into the amps?
Old Aug 24, 2010 | 08:32 AM
duro78's Avatar
duro78
What H/u are you running?
Old Aug 24, 2010 | 09:00 AM
StreetOC192's Avatar
StreetOC192
For the Kicker unit you linked to, you wouldn't. You would only use the front outputs from your headunit to feed the EQ. Use the built-in crossover in the EQ to distribute the signal. This would render the balance/fade/sub-level adjustments on your headunit useless. This unit applies the EQ then splits the signal via its built-in crossover.
For the AudioControl unit you linked to (very nice unit btw), it has 6 channel preamp inputs (2-fr, 2-rr, 2-sub) with independant EQ points for each set of channels.
Old Aug 24, 2010 | 10:30 AM
Ziggyrama's Avatar
Ziggyrama
I am running JVC AVX-800:
http://www.crutchfield.com/S-TnpFWIO...KW-AVX800.html
It's a decent HU with lots of nice features but I find the EQ lacking (7 band) and I'd like to get a bit more flexibility there.
Gotcha. So, essentially, I need to find an EQ that will support 5 channel input if I am going to run all of my output through it. That makes sense. The AudioControl unit seems like a nice piece of equipment. Ok, so this gives me a baseline to go by when selecting my EQ. Thanks for the help guys!
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
