Looking for a new sub
Old Oct 5, 2010 | 09:42 AM
DBTre50z's Avatar
DBTre50z
Default Looking for a new sub
So i currently i have a setup which consists of an alpine stereo, alpine speakers, a RF 500 watt amp and a 12 inch P3. I am almost certain that I am going to upgrade my P3 to a 15 inch sub . The reason why i figure a 15 over a 2nd 12 is because it would take up the same room and would most likely take the same power so instead of sharing a box with 2 subs, why not dedicate the whole box to one? I also would like to be able to hit some higher numbers, preferably mid to high 140's. So after doing some experimenting in the trunk, i can probably make a box about 3.5-3.75 cubic ft. I also did my research on subs and narrowed down my searches to what i seem to like. The choices are
1. Audioque HDC3 15
2. Fi BTL 15
3. Orion HCCA 15
4. RE Audio XXX 15
All of these i think are high quality subs and are worth the money. I am especially interested in the Audioque and Fi subs. I would also of course be upgrading my alternator to a power bastards 220 amp and eventually my amplifier once i can shell out the extra dough. If there are any other recommendations on subs (other brands or reviews) please let me know. And i am expecting some negative comments about putting a 15 inch sub in however try to keep it on topic and only helpful answers please
Thanks
Old Oct 5, 2010 | 10:33 AM
350zspl's Avatar
350zspl
i use a digital design 9515G 15"
you can do 31 " width max external
14" height max external
19" Depth external max
driver and port up yeilds the higest #
i am seeing 148-149 sealed up on the TL
159 outlaw on the audiocontrol
you will see 3 net cu feet after port and sub dispalacement
possible 3.25 net pending sub and port choice
what is your budget
were do you want your tuning
what music do you listen to
what amp
what alt
what awg wire how many runs
500 watts won't make any of those subs even move man sorry try to shoot for 2500 watts to start
you will need a new amp
Old Oct 5, 2010 | 10:57 AM
bmccann101's Avatar
bmccann101
i agree totally.
I run 2 10w7s, 1k watts mono, 10 farads, and 1 gauge wire.. stock alternator will be toast in a few months now im sure.. and sice its stock i mof course not making nearly full power... cant turn it up barely anyways... but yeah.. get high throw speakers versus a big #ss 15 my friend. The reality is that the frequencies that really put up spl numbers are NOT subsonic, and are in fact quite high in comarison anyways.. not to mention im sure you want to actually drive it daily and listen to MUSIC in it, not just sweeps and tones.
Old Oct 5, 2010 | 12:13 PM
350zspl's Avatar
350zspl
i have run RE MT which is an spl sub
i have run FI BTL spl sub as well
and i have run audioque hdc3 as well copper coil will sound better on music and the aluminum coils handle more power
let me know your budget and what tuning you want i think i can help you make the right choice
i have used almost every sub and box , and amp configuration in the 350z since 2006 geared toward spl
Old Oct 5, 2010 | 01:15 PM
DBTre50z's Avatar
DBTre50z
what is your budget
what amp
what alt
i was considering doing a box that consisted of wood and fiberglass, the wood will outline the bottom of the car and the sides and the fiberglass inside the box as well as fiber glassing the top of the box. I dont know if i should just glass the inside of the box and make it out of all wood or what. A suggestion on that would be good.
I was considering tuning it at around 35 hertz, this way i can hit those lows but i can also put up some descent numbers.
I mostly listen to rap/hip hop however i enjoy listening to rock and whatever else they play on the radio (except for country )
I was looking at the Audioque AQ2200D which with a power bastards 220 amp alt i think would be good.
i agree totally.
Yes you are right, i do want to just be able to listen to music. I figured i would dedicate the trunk just to 1 large sub, my reasoning being it would be louder than a 12. What 12's would you suggest?
Old Oct 5, 2010 | 01:19 PM
DBTre50z's Avatar
DBTre50z
What positive/negative things do you have to say about the Fi and Audioque subs? Something about the hdc3 appeals to me, probably the price and performance.
Do you by any chance have a picture of your setup so i can get an idea of how it would look?
How does a 15 sound as compared to other setups you have had (12's, 10's) would you recommend one setup over the other?
Old Oct 5, 2010 | 01:27 PM
350zspl's Avatar
350zspl
if your not doing a solely dedicated spl enclosure than 3/4" mdf or birch , or trupan, just glass the inside so it is smooth , 1.25" baffle, all interior corners 45 degreed, , solid internal bracing , driver and port up, 35 hertz will do well on music and hit a tone at 42-47 hertz
i would recommend a 200 amp wrangler alt over the one you have mentioned
audio que 2200 is fine though i would get a sundown saz 2500 over that amp ( i am a sundown dealer hence i am biased ) though you can post a thread on any car audio forum and i think you will see i am correct
Old Oct 5, 2010 | 01:33 PM
350zspl's Avatar
350zspl
fi btl & audioque are more spl orientated than musical
fi btl handles more power than the hdc3 and sounds better on music
though both are a stretch for what i would consider a muscial driver
i feel a 12" driver like a btl or hdc3 or Digital design 12" g series motor , or sundown nighshade V2 12" will load better and get just as loud in the same space of a 350z , as the 15" in that space is on the small side
you are considering giving any of the above drivers RMS so a 12 will load better in that space
i use a 15" in a smaller box because it allows me to grossly over power it in a box on the 3.25'net side over a 4' net size
again if you are choosing the above drivers and running rms you may do better with a 12"
you can't even compare the RF p3 in 12" to what i am saying it is a whole different thing
so go with a 15" sub if you can see yourself feeding it 3000 + watts
otherwise 2500 or less do 1 each 12"
but it is close either way and box dependant
Old Oct 5, 2010 | 01:43 PM
DBTre50z's Avatar
DBTre50z
If i bought the Audioque HDC3, do you think I would be good with the copper coils if i want to listen to my regular music, just with some heavy bass? Or if im looking for that heavy bass in music i should opt for the aluminum coils?
Old Oct 5, 2010 | 02:16 PM
w8lifter21's Avatar
w8lifter21
When I had my 350z I was running an Orion HCCA 10. It was a bit overkill, but I enjoyed it
Old Oct 5, 2010 | 04:02 PM
350zspl's Avatar
350zspl
you said 35 hertz
tells me your leaning more toward music
with a run in the lanes from time to time
that combined with an aq 2200 , after imp. rise and voltage drop you may see 1800 watts
copper will be fine
Old Oct 5, 2010 | 04:05 PM
350zspl's Avatar
350zspl
at least pm me what your paying for the aq 2200 & the aq hdc3
you should consider a sundown nightshade v2 and a saz 2500
the sundown will get louder in less space and sound better doing it
Old Oct 5, 2010 | 04:08 PM
350zspl's Avatar
350zspl
as far as pics i don't have a camera
wrangler 200 amp alt
dd 9515g
ddw6.5 mid bass
dda 5.25 mid range germs
cdt drt 26 tweets and 560i crossovers
sundown saz 2000
sundown sax 125.2
stinger batts & interconnects
6 runs 0 awg
alpine 9886 hu
roughly 100 sq ft of stinger roadkill
Old Oct 5, 2010 | 06:35 PM
DBTre50z's Avatar
DBTre50z
you said 35 hertz
copper will be fine
Thats exactly what i was getting at
After you telling me about the sundown equipment i went onto the website. I found information on the amp but it seems a little out of my price range. I read a bunch of reviews though and only great things were said about sundown. I checked for the sub though and didnt see anything.
A HDC3 15 with a copper coil is 270 plus shipping from their website. The amp is 390 shipped from their website.
After some of the suggestions above i may consider a fi btl 12 inch in a big box and hope fully still produce some good numbers.
dd 9515g
ddw6.5 mid bass
sundown saz 2000
sundown sax 125.2
6 runs 0 awg
alpine 9886 hu
Wow sounds heavy both sound and weight
Old Oct 5, 2010 | 06:40 PM
350zspl's Avatar
350zspl
i am authorized dealer
the sundown is 2 yr warranty on the amp
i will pm you price
high decibel audio
FL
Old Oct 5, 2010 | 06:44 PM
350zspl's Avatar
350zspl
quote sent
subs are build to order
you pick spiders & coils & leads can do push terminals or 24 " of raw 8 awg leads
Old Oct 11, 2010 | 07:55 PM
DBTre50z's Avatar
DBTre50z
Thank you for all of your help. I apologize for not getting back sooner but i appreciate all of the suggestions. I recently had some other problems that need to be attended to first however i think when i do upgrade i will be going with the orion. It just seems like a solid sub. Thank you again
Old Oct 13, 2010 | 01:56 AM
duro78's Avatar
duro78
From what i saw they dont make wrangler alts for our car. Try powerbastards they're cheaper plus Ive heard good things. Im running an aq2200 right now make sure your electrical is up to par
Old Oct 13, 2010 | 05:11 AM
mxdustinmx's Avatar
mxdustinmx
Go with the BTL, i loved my 18'', but then again all those other subs you stated are all nice
Old Oct 13, 2010 | 10:24 AM
350zspl's Avatar
350zspl
wrangler does make alts for 350z
i have one in my 350z
been using wrangler for years
runs anout $550 shipped
2 week lead time
200 amps at 1500 rpm or better
