Need help on hooking up an MP3 player
on
I have an 03 touring. That comes with the bose and the 6 CD changer. I've been using the search tool for a while and have been only able to find posts for different years and trims, and most are for the radios with the sat button. I have the stock stereo and all it has is CD, Tape, and AM/FM. I have the cassette adapter but for some reason no low notes go through it, so it doesn't even sounds like i have the sub behind the seat. All i want to do is wire a 3.5mm audio in to the stock radio so I can listen to my MP3 player with some bass!
If there are some posts already on this that you know of please just point me in the right direction. Maybe i was just searching for the wrong key words. But everything i found didn't seem to apply to my Z
on
or you can get one of those FM adapters that you can connect to your MPplayer and listen to you MP files thru your FM radio. Monster has a good adapter,but beacuase its playing thru your radio, you may get interference depending on your area. The real fix is upgradimg your head unit with a built in MP3 connection.
bcoffee20
11-19-2015 06:39 PM
xirtam
10-03-2015 02:06 PM
ILoveDrifting
09-07-2015 03:15 PM
