a night of hell avic 700bt install... Funny.
Old Dec 16, 2010 | 04:31 PM
archangel0585's Avatar
archangel0585
Default a night of hell avic 700bt install... Funny.
So I'm installing my stereo and I've wired up the bypass. Well, I hooked it all up and the bypass wasn't working so I unhooked it and worked out the kinks (turns out the light green wire was missing, "the parking break line" and I had to splice a new wire into the harness) but as I hooked it up the radio wouldn't work, and my gauges were dead... panic.
we(my friend and I) worked through every possible solution... nothing was working. THEN FINALLY A MOMENT OF CLARITY. The radio will not turn on unless the antenna is hooked up....
ok antenna hooked up it fires up... 3 hours later we figure out the aforementioned missing wire from the harness and hook it up... NOW I HAVE A RADIO AND A GPS... but my gauges were still dead.
figure out it's the daisy chained upper gauges... hook them up... still no tac or speedo. refuse to panic again... reinstall the AC controller... boom I have a tac.
between snaking the mic, the GPS unit, reflashing from the old f series firmware, and wiring the bypass.... total install went for 6 hours plus.
but it was worth it. I have 2 map sets, and all features work when the car is moving. I only panicked 3 or 4 times, and now I know what ever wire in every harness in my car is.
I fell asleep in the garage for a bit... it was surreal... I woke up staring at my Brembos.
Attached Thumbnails a night of hell avic 700bt install... Funny.-inside-3.jpg   a night of hell avic 700bt install... Funny.-inside-2.jpg   a night of hell avic 700bt install... Funny.-inside.jpg
Old Dec 16, 2010 | 04:51 PM
omsin523's Avatar
omsin523
Well happy you got it working!
Old Dec 16, 2010 | 05:33 PM
importdemon5's Avatar
importdemon5
Anyone know if you can hook the light green wire up somewhere else other than the e-brake to get the monitor to play dvds while you are driving?
Old Dec 16, 2010 | 05:53 PM
Marcus93's Avatar
Marcus93
Just hook the wire to a switch then ground the switch. When you want to watch a DVD you just flip the switch.
Old Dec 16, 2010 | 07:25 PM
dcastillo819's Avatar
dcastillo819
no need for a switch just go here and watch http://www.youtube.com/watch?v=8HL5pkAKkkA
This is what i did when i hooked up my avic-z110bt. It has never gave me any problems.
Old Dec 17, 2010 | 01:38 AM
mjm26's Avatar
mjm26
great story
Old Dec 17, 2010 | 12:08 PM
archangel0585
thanks, and to answer the question I used the hard wire bypass on the avic forums. you should check it out.
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
