Amp question
Old Dec 22, 2010 | 11:05 PM
NismoZZ's Avatar
NismoZZ
Default Amp question
Im going to be installing two amps in my Z. Both are pioneer amps one is a GM-D9500F 4 channel amp RMS 75X4 at 4OHMS and a GM-D8500M mono amp RMS 400. I have been looking everywhere and can't find a clear answer. Do i need to put a relay on the remote turn on wire for these two amps? This is all i will be running just two amps nothing more or do you guys think it will be okay to just run one wire to one amp then another small wire from that amp to the other thanks any help will be appreciated thanks
Old Dec 23, 2010 | 03:08 AM
DavesZ#3's Avatar
DavesZ#3
Moved to proper forum
Old Dec 23, 2010 | 05:36 AM
350zspl's Avatar
350zspl
do you have a stock head unit or aftermarket
if a stock head unit pull trigger from the fuse box, use a fuse tap, and use a fuse that is not constant power , only a fuse that gives power when key is turned on, though voltage is low you are still using it to run a bit of power so use 1 amp fuse on the wire as not to start a fire, 12 to 18 awg should do and you can trigger both amps with one wire just splice it at the amps to make 2
if you have an aftermarket head unit it should have a trigger wire to source
Old Dec 23, 2010 | 05:24 PM
NismoZZ's Avatar
NismoZZ
I have a after market headunit pioneer. What do you mean trigger wire ?
Old Dec 23, 2010 | 05:55 PM
Z1NONLY's Avatar
Z1NONLY
If you are asking if two amps will be too much of a current draw for the remote turn on lead of your head unit, the answer is "no problem".
The amplifiers' remote-turn-on inputs don't require much current at all. The main power terminals draw a lot of current but you are just concerned about the remote turn on, right?
Old Dec 23, 2010 | 07:22 PM
NismoZZ's Avatar
NismoZZ
yes just the remote turn on wire. I heard on diff forums that the headunit has something inside of it that can blow if to many components are hooked up to the remote turn on wire.
Old Dec 24, 2010 | 06:10 AM
Z1NONLY's Avatar
Z1NONLY
They have a maximum current draw for the lead, and exceeding it could very well damage your head unit.
But the amount of current pulled by an amp's "turn-on" input is a fraction of that limit.
Old Dec 24, 2010 | 06:20 AM
350zspl's Avatar
350zspl
trigger = remote
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
