tweeter location
Old Mar 12, 2011 | 06:57 PM
yahmeboys's Avatar
yahmeboys
Default tweeter location
im having a issue with placing my tweeters. I bought infinity components and the tweeters are to big to fit with factory mounting mold. i was thinking the door panel under the door handle. have anyone placed the tweeter beside stock location
Old Mar 12, 2011 | 08:05 PM
350zspl's Avatar
350zspl
kick panel or base of a pillar
not the door panel
Old Mar 13, 2011 | 06:03 AM
Tweeters are directional, and should be listened to "on-axis." Common mounting is ear level. Any other position is a compromise.
Old Mar 13, 2011 | 06:15 AM
cdoxp800's Avatar
cdoxp800
Here is mine from when I had my3 50
https://my350z.com/forum/audio-and-v...placement.html
Old Mar 13, 2011 | 01:50 PM
Spike100's Avatar
Spike100
+1 on tweeter location... everything you need to know is in the referenced link posted by cdoxp800.
--Spike
Old Mar 13, 2011 | 04:54 PM
yahmeboys's Avatar
yahmeboys
arent there airbags there
Old Mar 13, 2011 | 07:35 PM
bmccann101's Avatar
bmccann101
the only reasons people mount in the kicks is it generally offers the least difference in path length.. but placing them low is never quite optimal.
If you run good gear and have tweets w a low crossover point, they will cary most of the sound localization. Your BEST bet overall is to modify the stock tweeter location or place them at the far corner of the dash. Not completely on axis, both should face the center of the car, not you.
if you use any high level sound processing like i do, its almost non important.
Again, just modify the OEM tweeter pod.. easy and keeps u from cutting up big parts of your car.
Old Mar 14, 2011 | 08:14 AM
NismoZZ's Avatar
NismoZZ
I installed mine here and they sound great you can always adjust the settings on the headunit
Old Mar 14, 2011 | 04:11 PM
Spike100's Avatar
Spike100
Where's "there"?
--Spike
Old Mar 15, 2011 | 08:02 PM
yahmeboys's Avatar
yahmeboys
never mind my last post lol i was think of something else
Old Mar 17, 2011 | 07:55 AM
TURBOROADSTER's Avatar
TURBOROADSTER
Just use a hole saw to cut the factory Tweeter panel . Flush mount your tweeter into the panel . This is what I did , took maybe 5 minutes per side .
Old Mar 28, 2011 | 10:14 PM
John H.'s Avatar
John H.
I have the Kappas, and installed them in the door panel. Came out great. BTW, my Kappa x-overs were installed behind the door panel (yes there is space), simply, I zip tied them to existing holes.
Old Mar 29, 2011 | 01:57 PM
Spike100's Avatar
Spike100
^^ The Z's Sail Panel is not the best position for tweeters, but Nissan obviously chose this position for some reason.
--Spike
Old Apr 1, 2011 | 08:38 AM
Nazar's Avatar
Nazar
Stock location for tweeters can be modified to accept larger tweeters, You just need to do a little bit of cutting and possibly bondo or fiberglass work. Then refinish them black or any other color you want.
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
