The TS-W258D4 10" subwoofer
Old Mar 18, 2011 | 01:24 AM
ZSOLDIERHOOAH's Avatar
ZSOLDIERHOOAH
Default The TS-W258D4 10" subwoofer
Im new to this site but, I was wondering what you guys think about this set up..
(2) TS-W258D4 10" pioneer subwoofer + lanzar opti2000d 2000w mono car audio amp + Zenclousure Box + 4 GAUGE 2000W AMPLIFIER WIRING KIT AMP INSTALL KIT...
SUB FEATURES:
PRICE: $114.99
SHIPPING: $6.99
10" subwoofer with dual 4-ohm voice coils
Aramid fiber-reinforced IMPP cone
3-layer urethane and fiber-woven radial surround
stamped steel basket
switchable to 8-ohm or 2-ohm impedance configuration
power range: 50-350 watts RMS (175 watts RMS per coil)
peak power handling: 1,200 watts
frequency response: 20-450 Hz
sensitivity: 90 dB
top-mount depth: 5-5/8"
sealed box volume: 0.65-1.25 cubic feet
ported box volume: 0.9-1.55 cubic feet
warranty: 1 year
AMP FEATURES:
PRICE: $299.99
700 Watts RMS Power @ 4 Ohms
1100 Watts RMS Power @ 2 Ohms
1600 Watts RMS Power @ 1.3 Ohms
2000 Watts Max Power @ 0.5 Ohms
4000 Watts Bridge Max Power @ 2 Ohms
Mono Block Subwoofer Amplifier
0.5 Ohm Stable
MOSFET Power Supply
PWM (Pulse-Width-Modulated) System
Double Sided Epoxy PCB Circuit Board
Gold Plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload Short Protection
Remote Bass Control
Soft Turn On/Off
THD @ 1Watt/4 Ohm: 0.1%
S/N Ratio: 90dB
Frequency Response: 15Hz - 150Hz (+/-3dB)
Damping Factor @ 20Hz/4 Ohms: 400
Low Pass Filter: 50Hz-150Hz, 24dB/Octave
Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave
Variable Bass Boost: 0 to 18dB
Variable Phase Control: 0 to 180
Input Sensitivity: 200mV ~ 8V
Input Impedance: 10k Ohm
Line Output Impedance: 100 Ohm
Fuse Rating: 30A x 6
Dimensions: 10.08'' (W) x 2.12'' (H) x 19.1'' (L)
2003-08 Nissan 350Z 2-10" Subwoofer Box
PRICE: $74.99
SHIPPING: $30.00
As with all of our subwoofer enclosures we have designed this box to be easily installed into your car. The box is installed directly under the strut bar in the hatch area. It fits firmly into place without removing or modifying any part of the car.
Mounting depth - 7.00" (Based on a 6.125" diameter magnet.) Most subs 7" deep or less will fit.
Mounting diameter - 9 1/8"
Airspace Volume- 0.75ft^3 !
Material- 0.75" MDF
Covering- Automotive Carpet
Wire Terminals- 2 Located on Sides
Wiring kit:
PRICE: $19.99
SHIPPING: $6.99
16ft. Red Power cable
3ft. Ground Cable
15ft. Blue RCA cable
15ft. Blue Remote Turn on wire
20ft. Speaker cable
Platinum AGU In-Line fuse holder
Platinum 60amp AGU fuse
Gold ring terminals
Spade Terminals
Butt Connectors
Loom Tubing
Self tapping screws
Cables Ties
Grommets
Old Mar 18, 2011 | 01:37 AM
terrasmak's Avatar
Overkill, a single 10 in the factory location is just great for a small interior.
Old Mar 18, 2011 | 01:55 AM
ZSOLDIERHOOAH
I purchaced the set up already, but you think thats too much?
Old Mar 18, 2011 | 03:55 AM
Strollo22's Avatar
Strollo22
Depends on what you're looking for. Are you just looking for a slight upgrade over stock or are you looking to have heart palpitation kind of bass?
Old Mar 18, 2011 | 05:26 AM
ZSOLDIERHOOAH
2nd part im trying have some real beat in my trunk..and I thought that set up I purchased below would be decent for a beginner like me...only cost me 670$ for everything plus the installation fee 770$ in total I havent got the system installed yet because im in afganistan...but I was just wondering do you guys think what I bought will hit pretty nicely?
Old Mar 18, 2011 | 06:11 AM
350zspl's Avatar
350zspl
i think that i LOVE lanzar opti's
a 2000 lanzar opti needs to be run at .5 ohm to get 2000 watts
i highly doubt your electrical is up to running at .5 ohm
and i might add that at .5 ohm that Lanzar will beat the living dog Shitt out of those pioneer drivers
when i think subwoofers pioneer never enters my mind
what are you trying to achieve and what is your budget ?
Old Mar 18, 2011 | 07:29 AM
ZSOLDIERHOOAH
My budget is 1000$ and I just want some quality beat in my trunk I dnt know much about subs....I was told pioneer was good bang for its buck and that lanzar a good amp....I heard JBL,JL,and MTX are good but come with a high price tag....but you think this amp will destroy my subs?
Old Mar 18, 2011 | 10:22 AM
350zspl's Avatar
350zspl
have you already bought anything?
is the system 100% stock at the moment?
is the $1000 for an entire system, or just for sub, box, amp, power, ground, rca, trigger turn on, sub - & + leads, LOC? are you installing this or are you paying labor to a shop?
does you car have bose system?
are you leaving the factory radio and front & rear factory speakers?
what type music do you listen to?
that amps has the capability to destroy the drivers yes
Old Mar 18, 2011 | 08:03 PM
ZSOLDIERHOOAH
yes I purchaced the, Amp + Subs + Box + wiring kit= 670$
Installation fee= 100$
if you scroll to the bottom of the thread you will see the post and description of the items ive purchaced already
only thing I havent purchased yet is the head unit and yes the 1000$ limit for the entire system.....
Old Mar 19, 2011 | 09:25 AM
350zspl's Avatar
350zspl
$100 for the install is un-heard off , but if you can get it done for that, wonderful
it would take me at the very least 10 hours to complete that if i rushed
well if you already bought everything not really much to change or sway from your plan
if the drivers are DVC 4 ohm you can wire the amp to a 1 ohm load before box rise
just set the gains with a DMM and be careful
Old Mar 19, 2011 | 10:54 PM
ZSOLDIERHOOAH
ok thanks for the info really appreciate it
Old Mar 20, 2011 | 06:29 AM
Armed Ferret's Avatar
Armed Ferret
Typically if you're going to ask the forum's opinion on certain gear, it's best to do so BEFORE you've bought it.
Old Mar 20, 2011 | 08:18 PM
ZSOLDIERHOOAH
yea thats true lol...but i found out about this site after the fact but thanks for the heads up ill keep that in mind for future references
Old Mar 23, 2011 | 07:28 AM
SightSeeker's Avatar
SightSeeker
I just installed the single voice coil version and the 360W mono amp and it hits harder than I can stand it. I have the gain on about 1/8 a turn to balance with the speakers. 2 is a huge overkill unless you are trying for max dbs.
Also I built my box for $40 and bought the amp as a display model for $55 so the whole bass setup only cost me about $170.
http://www.pioneerelectronics.com/PU...ries/TS-W259S4
http://www.pioneerelectronics.com/PU...eries/GM-5400T
Old Mar 24, 2011 | 03:20 AM
ZSOLDIERHOOAH
Nice set up and subs for that price man Idk why so many people dislike pioneer from the reviews I and actuall customer feed back, they seem very durable and can hit on point if properly wired......well my whole set up in the end going to come out to 1100$ dollars because Im purchacing Polk Momos 6.5inch to replace my Bose in door speakers they will be running off a 4 channel amp...that combined with my pioneers running off that Lanzar Opti2000D amp should be more than enough bang for my (Z)....when I get back from my deployment Ill let you guys know how the setup sounds....
kyin
Oct 15, 2015 05:54 AM
SeattleInfo
Nov 13, 2005 10:33 AM
ranger5oh
May 16, 2003 08:53 AM
krutoydude
Apr 4, 2003 02:31 PM
