Alpine single din install help!!!
Old Mar 20, 2011 | 07:07 AM
azhusker14's Avatar
azhusker14
Exclamation Alpine single din install help!!!
I am installing an alpine CDE-9870 single din HU in my 2005 Z. I have the Alpine wiring harness soldered up to the Nissan wiring harnesses but where do i connect the ground? if i just solder the black wires together in the two wiring harnesses i noticed that there is nothing on the car side of where the black wire is on the Nissan Harness?
Any help would be greatly appreciated
Old Mar 20, 2011 | 08:51 AM
Squeez'n'Z's Avatar
Squeez'n'Z
you can always just ground it to a bolt
Old Mar 20, 2011 | 08:54 AM
azhusker14's Avatar
azhusker14
That's what i just tried... didnt work. Guess i did something else wrong in the wiring. Time to pull out the multi meter and get to testing.
Thanks for the help though.
Old Mar 20, 2011 | 01:09 PM
LuciaPwNs's Avatar
LuciaPwNs
make sure the the bolt is actually grounded.
Old Mar 20, 2011 | 02:55 PM
Spike100's Avatar
Spike100
I’m not certain I understand your question. Please forgive me if my reply is not helpful.
If you do not have a ground when combining the OEM and aftermarket harness, you simply ground to an appropriate position that is convenient and reliable.
--Spike
Old May 9, 2011 | 10:54 AM
bmccann101's Avatar
bmccann101
hey Husker.. is this Dwayne?
You get yer ground issue figured out?
Old May 9, 2011 | 05:03 PM
saywat?'s Avatar
saywat?
gotta be something else. i installed my deck and forgot to ground and it worked perfectly for 2 days until i realized that i forgot to do it. but yea like the other dude said jus screw in on any bolt thats attached to metal should be good enough
dcains
Nov 11, 2015 11:36 PM
