Location for IDMAX 12" - want to keep spare tire
Old Apr 17, 2011 | 01:58 AM
BlueSQ's Avatar
BlueSQ
Default Location for IDMAX 12" - want to keep spare tire
I'm doing some math and between the tools, materials and my time, I might as well buy a prefab Zenclosure. Thing is, their 12" enclosure sacrifices the spare tire. I've gone that route in my last car - never again.
IDMAX 12" D4 has a mounting depth of 8.25" and it should have at least .5" behind the magnet. Volume of box needs to be 1.5 cuft. Cutout is 11" and flange edge to edge is 12.4".
It wont fit in the area behind the driver seat - at least I haven't seen it work. The strut bar is juuuust too low to mount it underneath. Any ideas? I'm tryin to stick with a 3/4" mdf box with a 1" baffle side - so no fiberglass builds for this.
Old Apr 17, 2011 | 07:24 AM
dkmesa350z's Avatar
dkmesa350z
Oooh sweet, give me your IDMAX and I'll give you my 10" Kicker CVR - problem sovled. I freaking love IDMAX's.
Old Apr 17, 2011 | 09:18 AM
350zspl's Avatar
350zspl
does the id max want to be ported or sealed
how much space net does it require
Old Apr 17, 2011 | 01:21 PM
hugo350z's Avatar
hugo350z
if you want the best sq out of it in the hatch are my friend, the further away from you the better bass response)as well as positioning of course,id recommend facing the hatch glass so i deflects off of it at an angle)
Old Apr 17, 2011 | 01:49 PM
BlueSQ's Avatar
BlueSQ
Dream on
Old Apr 17, 2011 | 01:54 PM
BlueSQ's Avatar
BlueSQ
Sealed. 1.5 cubic feet. specs at 1.30 - 1.55, but Ive tried 1.45 and 1.55, so this builds gonna be 1.5.
How would you set that up? Accessibility to spare tire is a must.
Old Apr 17, 2011 | 02:49 PM
350zspl's Avatar
350zspl
build a sealed , 1.5 cu ft net after sub displacement, sub face up
will be light enough to pull out to access spare & jack
Old Apr 18, 2011 | 01:50 PM
SQBassHead's Avatar
SQBassHead
or you can just get AAA and make your life alot easier
this is what i did and too this day i havent needed it, so idk bro... the chances of you using your spare are slim
Old Apr 19, 2011 | 10:06 PM
BlueSQ's Avatar
BlueSQ
I hear ya. I have it too, but it doesnt help if I need to be somewhere in 15 mins. Flat tire is the laaamest excuse.
An excellent idea but a square or rectangle box doesn't look very custom.
Old Apr 20, 2011 | 04:22 AM
DBTre50z's Avatar
DBTre50z
Plus you probably wouldnt have the proper mounting depth. At least i wouldnt think so.
Old Apr 20, 2011 | 07:10 AM
350zspl's Avatar
350zspl
you can make a light removable beauty panel for a custom look
zenclosure makes a fine product and all users love them , but it is not gonna look that custom as there are many out there using it IMO but it is good
Old Apr 20, 2011 | 09:36 AM
chaparro78's Avatar
chaparro78
Sometimes you have to pick one or the other unfortunately. A square non custom box is also an easy target for a thief. I have had a flat or 2, hae always just used AAA. I have a set of original rims/tires at home in case it happens near by. I can just grab one.
Old Apr 26, 2011 | 05:18 PM
BlueSQ's Avatar
BlueSQ
If I reversed the design of the Zenclosure I could make the amp rack panel located between the seats and the strut bar into the baffle, angled up and firing forwards towards the windshield. Then I could turn the under strut panel facing the rear into a flat beauty panel and keep the spare.
Where theres a will theres a way...thoughts on forward firing subwoofers or the design idea?
Old Apr 27, 2011 | 05:28 AM
350zspl's Avatar
350zspl
foward does not sound nearly as good as backward or up
but you can try it
generally the shorter the path of the bass wave the worse it sounds
Old Apr 27, 2011 | 06:08 AM
SQBassHead's Avatar
SQBassHead
It sounds more boomy and drowns the highs easier
Old Apr 27, 2011 | 10:31 AM
hugo350z's Avatar
hugo350z
If so you can't the max is pretty big and a spare delete/fiberglass fabrication will have to be done, if you wanna have a spare have you considered a smaller sub? Also under strut bar zenclosure(w diff sub) box maybe no the best sq but access to spare is there.
Old Apr 27, 2011 | 01:21 PM
BlueSQ's Avatar
BlueSQ
I've considered an IDMAX 10 v4. Couple things keep me from swapping it:
- Lowest end frequency response diminished
- Image Dynamics is out of business and that 12" may become rare
- I won a couple IASCA comps with a single 12 - my substage always beat the competition for sq and it hit the max (135db) in a sealed box so its extremely versitile.
I moved the sub around in the trunk to see how it fits....its just too big for what I want w/o spending a fortune.
I'll most likely buckle and remove the spare. I have 3 amps for sub, mids and tweeters that need a home out of sight as well so my options just got more limited. Plus the Zenclosure setup with the amps under the floor would provide weight where the spare used to be.
Given everyones response about forward firing woofers I'll be nixing that idea too.
Looks like I have my options. Thanks guys - once the build's done I'll post pics.
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
