Kenwood KVT-512 HU Troubles
Old Mar 9, 2011 | 12:19 PM
NoQuestionZ's Avatar
NoQuestionZ
Default Kenwood KVT-512 HU Troubles
Edit: Updated. No WAY would I have figured that out by reading the manual. MODS Please delete!
Old Mar 9, 2011 | 04:05 PM
laser24's Avatar
laser24
not sure about kenwood but most high end HU's with usb update thru the usb.. basiclly copy the files to a jump drive that has fat32 file table ,plug it in ,power up HU , goto the update screen...
Old Mar 11, 2011 | 06:22 AM
NoQuestionZ
It says on the Kenwood update page that it can't be done via USB. I tried it once, but maybe I didnt have the right "format"? I don't know the difference between all that junk!
PLUS the dvd player plays sound, but no video? Idk what to do about that either.
Old Mar 13, 2011 | 10:08 AM
idkorcare's Avatar
idkorcare
in order for the ipod to work you have to use the kenwood ipod cable and not just usb. part# kca-ip300v (you might have to also adjust a setting, not 100% sure)
as far as video on the dvd did you hook up the parking brake wire(light green)
it either has to be grounded(always bypassed) or hooked to your parking brake and if hooked to the parking brake will only work when the parking brake is engaged.
I think you have to burn the update to to a cd in order for the update to load, i know the double din from that lineup updated that way.
Old Mar 13, 2011 | 10:23 AM
NoQuestionZ
I bought the KCA-iP302 version of the ipod cable since apparently the 300 is obsolete? Thats what the car audio guy told me.
I'll have to go in and look at the wires back there. It was my first deck install and my buddy's first DVD install so we were guessin and checkin.. It plays music though, so that's good!
Also, viewing pictures on this guy, do you know how to pull that off? I read it had to be in jpeg, but i have pix that are, and nothing comes up?
Thanks for your help
Old Mar 13, 2011 | 12:00 PM
NoQuestionZ
I grounded the wire just like you said. Man- that was easy. I was really intimidated by takin out the dash again, but I'm basically a pro after doin it 2x!
Still lookin for help on the ipod thing tho...
Old Mar 13, 2011 | 12:18 PM
idkorcare's Avatar
idkorcare
the 300 and 302 are the same thing as far as I can tell. If you have the usb, black, and yellow jacks all hooked up its probably an update issue. The kvt-512 is a year+(I think they made that model for a few years actually) old and if you have a newer ipod thats probably the issue.
I looked at the KVT-514 we have on display and I didnt see any menu setting that needed to be changed.
You cant really "view" pictures, especially from the ipod. The only way you can do it is to load them on a flash drive and go thru the motions like you are going to change the background to one of the pictures. Basically worthless other than changing the background. If you are refering to the "no photo" box that pops up when you select ipod that is for album art.
Old Mar 13, 2011 | 01:34 PM
NoQuestionZ
Well I have a USB with pictures on it, and the option to change the background is greyed out(unaccessable) last I checked anyway. I really want to change that background. I need to mess around with it more.
That update is killin me. My buddy has roxio and he tried 2 separate times makin it as a data disc but it just buzzes when I put it in there
Old Apr 19, 2011 | 10:42 AM
NoQuestionZ
Totally forgot I still had this post, still need help bump!
Old Apr 28, 2011 | 10:14 AM
NoQuestionZ
Bump-need help still!
pslamp32
Feb 8, 2017 09:07 AM
bcoffee20
Nov 19, 2015 06:39 PM
dcains
Nov 11, 2015 11:36 PM
amai21
Feb 21, 2003 09:33 AM
