05 350z radio issue
Old May 3, 2011 | 11:13 AM
dorikin's Avatar
dorikin
Default 05 350z radio issue
hey guys im new and i have done many searches with no answers, i have 05 350z with a stock radio, so when i turn the car off the radio still stays on, i have no idea what to do any help would be great.
Old May 3, 2011 | 01:02 PM
Welcome. Turn the radio OFF.
Old May 3, 2011 | 01:23 PM
VO...'s Avatar
VO...
Administrator
Thread moved...
Old May 3, 2011 | 01:58 PM
Spike100's Avatar
Spike100
The power wire for your radio should be connected to an ignition switched ACC wire. That way the radio turns OFF when the ignition is closed and the key removed, or remains ON when ACC is engaged or the ignition is ON.
I suspect that someone has swapped in an aftermarket radio and incorrectly powered the radio using a continuous power line (this is typically a yellow colored wire). That means the radio always has power unless you turn it OFF; the liability with this setup is an unintentional battery drain.
______________________________________
EDIT: I realize you state that your car has a 2005 stock radio. I mention aftermarket because some owners install a separate aftermarket tuner that is hidden but operated through the stock radio to maintain the factory look.
The other possibility is that the radio is rewired to remain ON until you open the car’s driver door. Some installation shops will do this setup. The radio is wired to a constant power line looped to an ACC power wire, and that power is only interrupted when the ignition is turned to OFF and the driver’s door is opened. Chrysler does this in the Jeep line. In this case you will not inadvertently drain the battery unless you sit inside your car for about 10 hours with the ignition OFF and the radio ON… not likely
--Spike
Old May 3, 2011 | 06:48 PM
dorikin's Avatar
dorikin
ok well when i turn the car off the display is still lit up, its not playing music, and every time i try to turn it off manually he display is still lit.
note: this has just started happening and has drained my battery a few times.
Old May 6, 2011 | 01:03 PM
Spike100's Avatar
Spike100
In that case, someone has previously pulled the radio, and when they replaced it, they managed to connect a power wire that supplies constant power.
You don't want that, so pull the radio, disconnect it's power, and locate a power line that is on the ACC ingnition switch.
--Spike
m_0g
Jun 3, 2021 10:05 AM
Sailors350Z
Sep 25, 2015 08:21 AM
issyz
Sep 12, 2015 04:18 PM
Darkspy
Sep 7, 2015 09:09 PM
