Avic Z130 Bypass Help
Old Jun 10, 2011 | 07:05 AM
Cool_Gray_350Z's Avatar
Cool_Gray_350Z
Default Avic Z130 Bypass Help
Hello fellow Z owners,
I completed the install of the my new Avic Z130 but had some issues with the bypass completion. I screwed up the area where the mute wire is located to complete the bypass. Is there another way to complete the bypass?
Thank You!
Old Jun 13, 2011 | 10:52 AM
Cool_Gray_350Z
Anyone?
Old Jun 22, 2011 | 02:31 PM
Cool_Gray_350Z
200+ views and no responses. Do any of you audio experts have a suggestion?
Old Jun 22, 2011 | 04:28 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
did you follow the instructions on avic411.com:
http://avic411.com/index.php?/topic/...30bt-bypassed?
its a different harness config than the z120bt, but the same principle applies
if you did exact that and it isnt working there are a few possibilities:
1. when you moved the pin over it didnt slide in correct so its not making a good connection. check the connection.
2. you didnt ground either this wire or the parking brake wire properly, in the Z, put both wires on a lead and then a spade terminal and physically ground it to a metal portion with in the dash area that measures ground with a test light or multimeter, i usually ground it to the metal mounting frame that the headunit and everyhting bolts into.
it has to be one of those two things if you performed the mod correctly.
b
Old Jun 30, 2011 | 11:24 AM
Cool_Gray_350Z
b
Looks like I will be removing the unit this weekend and go at it.
Thank You for your suggestions. I hope I get this unit to finally do everything it is supposed to.
Old Jul 2, 2011 | 08:37 AM
atrain858's Avatar
atrain858
i just installed mine in last week and followed the instuction on a you tube video on bypassing it. it took me no longer than 5 mins to complete the bypass. i dont know if you watched that video or not but if you didnt try watching it. all i did was remove the mute wire up one slot and connect the wires as they showed in the video and it worked great. the only problem i am having is with the radio. i got great reception when i had the stock indash in and with the alpine but now that i have this pioneer i aint getting reception for nothing. i dunno if it could be the short antenna that i had put on the car or if i miss connecting a wire in the harness or what. the antenna cable are all installed properly and everything. can anyone help me out with this issue?
Old Jul 21, 2011 | 08:09 AM
Cool_Gray_350Z
Hey buddy, I just saw this post. I have yet to get to getting the wiring corrected but I will be doing it this weekend since I have some free time. I'm as well having issues with the radio, really poor reception, I also have a small antenna, did you get down to the bottom of that issue? I will see if maybe a missed something while putting everything together.
On another question related to the unit, which area did you tap in for the vehicle speed sensor? I have seen either #20 or #26 on the AC module.
Thank You!
kyin
Oct 15, 2015 05:54 AM
Beater350z
Sep 9, 2015 03:36 PM
G35Couper
May 20, 2004 04:06 AM
Oh4aZ
Mar 14, 2003 05:45 PM
