Ipod installation
Old Aug 21, 2011 | 08:09 PM
ZilverstoneZ's Avatar
ZilverstoneZ
Default Ipod installation
Just finished my Ipod installation. I used the following parts:
KUDAŽ OEM Leather-Mount - iPhone GPS hands free - for NISSAN 350Z (03-05) black
iPhone & iPod Pass Through Cradle / DICE DCR-50
both of these purchased from: www.kudausa.com
Also have the PAC15-NIS interface that connects to my Bose (not seen).
Here are a few pictures of the finished job:
All of the items were quite easy to install, the Kuda leather mount has tabs that slide into the space between the shift finisher and the side plastic. There is one screw/connector at the bottom that holds it to the side dash panel but requires no drilling, that way should I remove it there will be no sign it was ever there. The Dice DCR-50 is a pass-through setup so all I have to do is slide my Iphone into it and off I go. Where I mounted it makes it quite easy to reach the iphone. As you can see in the pictures the Bose radio sees the PAC interface as a XM receiver. Of course you could install any type of phone mount to the KUDA.
Old Aug 21, 2011 | 08:14 PM
Bmurray350z's Avatar
Bmurray350z
looks good.
Old Aug 22, 2011 | 06:47 PM
Motox986's Avatar
Motox986
Default Nice
I like this. Think you could make a post about the mount I see for your GPS?
Old Aug 22, 2011 | 07:58 PM
ZilverstoneZ
Actually I dont have a mount for the GPS, just wedged it into the cubby and it stays put. I just routed the hookup wire through the small hole in the back of the cubby and plugged the other end into the 12v socket on the passenger side kickpanel.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
