Help with new headunit install
Old Apr 18, 2012 | 05:52 AM
noboostzcar's Avatar
noboostzcar
Default Help with new headunit install
Hey folks, I'm replacing my Pionner headunit with a navi unit but when its all hooked up I have to turn it all the way up to hear it. I have the amp wire hooked up and when its hooked up theres sound but very faint if the wire is taken off there is no sound so the amp is turning on when the wire is connected. I'm using the harness from crutchfield it uses rca jacks and I have them put into my front and rear off the headunit like the manual says to do. Why is the thing so dang quiet and if I bypass the factory amp with the speakers be louder?
Old Apr 18, 2012 | 06:11 AM
JERZ350's Avatar
JERZ350
Could you give a little more information, maybe what is the rest of your setup like? Aftermarket, OEM, BOSE?
Old Apr 18, 2012 | 06:40 AM
noboostzcar
all stock munis the headunit which is an erisin and my car is stock bose with navi
Old Apr 18, 2012 | 07:01 AM
JERZ350's Avatar
JERZ350
Are you using the PAC-ROEM NIS2?
http://www.amazon.com/ROEMNIS2-Inter.../dp/B000CE9OY2
You would need to use that with factory BOSE.
EDIT: Just noticed you said you already had an aftermarket radio working 100% in there? Also, you said you have the stock NAVI, and you're putting in another navi unit?
Old Apr 18, 2012 | 07:26 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Apr 18, 2012 | 07:27 AM
noboostzcar
I'm using a crutchfield kit but I found what the issue is my preamps are 2V insted of 4V like the old headunit guess I'm gonna install new speakers so what exactly do I need to do?
Old Apr 18, 2012 | 07:37 AM
JERZ350's Avatar
JERZ350
Gut the whole thing, new speakers, new amp, new sub(s). At that point its just like any other car, get the right sizes, look in the audio forum for ideas. Decide if you want to use the stock sub location or in the back.
Old Apr 18, 2012 | 09:26 AM
noboostzcar
Got it to work with just a walmart harness speakers work and sound great. Thanks to the guys at sound on wheels in huntville al for explaing to me over the phone how to make it work they seem to be great guys never bought a thing from them and they still helped me out. It only cost $11 for the harness at walmart.
dcains
Nov 11, 2015 11:36 PM
