factory nav not getting gps signal
Old Apr 27, 2012 | 01:07 PM
noboostzcar's Avatar
noboostzcar
Default factory nav not getting gps signal
My nav was working great until the past few days now the little satilite is grey and the navi is showing me in the wrong place ive driven over 100mi and nothing any ideas my car is an 04
Old Apr 27, 2012 | 01:41 PM
DavesZ#3's Avatar
DavesZ#3
Antenna broke/disconnected?
Old Apr 27, 2012 | 02:10 PM
noboostzcar
Na havent messed with anything to disconnect or break it
Old Apr 27, 2012 | 02:13 PM
Duckeee's Avatar
Duckeee
does not mean it cant malfunction. id check the antenna first
Old Apr 28, 2012 | 03:31 PM
Spike100's Avatar
Spike100
These are reasons you can suddenly lose GPS function:
1) Your antenna is occluded, damaged, or the wire is disconnected at either end (the device or the external receiver).
2) You have a contract for your device that can expire. This is often connected to cellular service. OnStar is an example. I doubt this is the problem you are experiencing.
3) The device itself fails. That is not unusual with the Clarion OEM system that Nissan uses in its cars. That may well be the reason in your case since your device is dependent upon a less than reliable disk player system. Nissan uses Xanavi application software (Xanavi is Clarion’s GPS division).
Your Nissan dealer can help determine the reason your system is not working.
--Spike
Old May 3, 2012 | 08:14 AM
ordinaryme's Avatar
ordinaryme
does factory NAV work through same antenna as radio? maybe for example changing to stubby antenna can cause signal failure?
Old May 3, 2012 | 04:00 PM
Spike100's Avatar
Spike100
He reports not changing anything. --Spike
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
