Subwoofer Wire Colors
Old May 16, 2012 | 05:00 PM
000's Avatar
000
Default Subwoofer Wire Colors
I'm putting a new 10'' speaker into the slot where the oem one is...its a 2003
Do you guys know which wire is positive and which is negative? I pulled off that black protector over the wires and I see a yellow wire and a black/white wire.
I just don't know which is positive
Old May 16, 2012 | 06:20 PM
TURBOROADSTER's Avatar
TURBOROADSTER
If the oem bose sub has a plastic molex plugged in , unplug it from the sub , cut the plug off leaving at least 2 inches of wire attached . Plug it back into the sub . Take a AA or 9v battery and hook one wire to + and one to - on the battery . When the sub pushes out , note what color of wire is going to the + on the battery(this will be your + speaker wire) . If the sub cone pulls in , simply reverse the wires on the battery .
Old May 16, 2012 | 07:42 PM
000's Avatar
000
thanks for the advice...I would try that but the only problem is when I bought this car there wasn't a sub in it...its just the empty hole...so I'm sticking my own 10'' in there I just can't tell which wire is positive and which is negative...again one is yellow and the other black/white
Old Jun 6, 2012 | 07:48 AM
jtk07's Avatar
jtk07
Question
Have you tried a test light?
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
