Pyle PLDN73I double din help.
So I bought this and bought the scosche dash kit for the 03-05 350z. To make sure everything worked I plugged in the unit and wiring harness and everything worked great. It puts out more watts than the stock system so it sounds a lot better. That's a plus. The Scosche in dash kit however was too small so I got out the dremel and went to work. Made the hole just big enough for the thing to fit through and put everything back together. Well the door would no longer open. So I looked at it and decided that the door didn't have any room below it to swing out. So I took everything back apart and cut the bottom piece off the dash kit so there would be enough room. Just to ensure that the door still game down I plugged everything back in before I put it back in the dash kit and indeed it worked fine. So I put everything back together once again and the door still wont come down. What the heck do I need to do to get this thing to work without making my dash look like a complete POS. There is a tiny amount of space on the two sides, the top is touching and the bottom has about a 1/4 inch of clearance. Has anyone else installed this and can help? Thanks in advance.
sure i can help.. Pyle has been building total crap for 20 years becuase there continues to be a market for those who wish to purchase 200 dollar decks that appear to have the same features as the 800 dollar ones..... throw it away and start over. Sorry man.
I had somewhat the same problem. What remedied it was a metra double din dash kit and widening the holes on the metal brackets. The metra kit will seem a bit large when you test fit it, but when it is fully installed it fits snug. Also make sure all of your wiring is tucked away enough so that there is no extra pressure pushing on the door.
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
As I have mentioned before, when you test fit, you're going to think, "Wtf?!" but when installed it will fit snug. Scroll down to section "B" of this tutorial for more reference:
https://my350z.com/forum/audio-video...monitor-5.html
You would think someone with your post count would actually contribute to a thread . I see threads all the time by Newbs that make me say WOW . If I don't have anything positive to contribute , I usually just move on . We all know the subpar quality of , Pyle , Boss ,etc , but maybe this person can't afford Alpine or Pioneer( Also no where near as good as the Japan made stuff) . I would try to help fix his dash kit fitting problems rather than bash his deck and tell him to start over . I know newbs are very frustrating , but it seems the older forum members should at least try and help them , rather than have sarcastic remarks every post .
OP I have a Pyle pldn76db and I had this SAME problem. It turned out that the stock mounting brackets squeezed the front of the unit just enough so that the screen didn't come down.
Yeah I originally bought the Scosche one as I said and all it comes with is the face plate. I bought the metra one and it has the spacers in it so I think that this one will work much better. I like the system over all. It sounds better than the bose head unit did.
Workshop12
Mar 23, 2020 01:45 PM
