help with new dvd radio install plz
Old Jun 7, 2012 | 07:59 AM
LosTViet's Avatar
LosTViet
Default help with new dvd radio install plz
ok i have a 06 z touring with bose & navi
last night i installed but no power was getting to it so i looked under the hood and the fuse was ok
then i unplugged it and put the factory cd player back and it work
any help will be great full
this is the part
MODEL : 99-7602
http://www.ebay.com/itm/200665456180...84.m1423.l2649
help me plz
Old Jun 7, 2012 | 08:09 AM
DBTre50z's Avatar
DBTre50z
On the wire harness that plugs into the back of your new radio and into the factory harness i think there are two different grounds, where did you ground them?
Old Jun 7, 2012 | 08:50 AM
LosTViet's Avatar
LosTViet
black to black , red to red, yellow to yellow , blue to blue ,
Old Jun 7, 2012 | 09:50 AM
bjjbadboy's Avatar
bjjbadboy
I'm rusty but you need to ground the other ground to the chasis
Old Jun 7, 2012 | 12:20 PM
GraysZ's Avatar
GraysZ
Shouldn't be the fuses. What type of aftermarket unit are you installing? First thing id do is recheck ALL your wiring harness connections and the big black male ended wire. (I know, sounds dirty).
Old Jun 7, 2012 | 08:47 PM
LosTViet's Avatar
LosTViet
long story short the fuses under hood was ok , the wires was all ok , the small fuse behind dvd player thats hooked to the red wire was fried . i was thinking just about running it strait without a fuses what u think
Old Jun 7, 2012 | 08:50 PM
LosTViet's Avatar
LosTViet
not really on a after market plug theres a black wire its for the ground , but yes you are right you can ground it out to the chasis if need be
Old Jun 8, 2012 | 05:03 AM
jtk07's Avatar
jtk07
Exclamation
DANGER Will Robinson!!!
Always Ground power wires - if I recall Red wire is for the key switch ignition power on off you DO NOT want to short back to the ignition switch! Highly NOT advised!
Old Jun 8, 2012 | 08:42 AM
Patrick250's Avatar
Patrick250
I just went through this installing my new HU. With the bose system the black wire in the larger white connector of the install kit is not ground at all. It is the shield for the signal cables going to the bose amp.
Stupid bose system.
I ended up connecting the black wire from the install kit and the black wire from the HU to a ground point that I found behind the triple gauges. I had to dremel out a little plastic and do some fishing to get to it.
File Type: pdf
Old Jun 8, 2012 | 10:15 AM
LosTViet's Avatar
LosTViet
yea just hit that part i was like hmm ok new fuse got power now but still not on ..... so i cut the black wire and ran it to the chaise . now it all works but cant seem to get the HU to bolt up to the Brackets it came with
Stupid bose system.
Old Jun 8, 2012 | 10:16 AM
LosTViet's Avatar
LosTViet
you was right thanks
Old Jun 8, 2012 | 10:35 AM
jtk07's Avatar
jtk07
OK I will be installing an after market harness metra brand with bose connections on a 2005 350zr. I dont want to burn any wires up so i am trying to figure out what went wrong here?
Are you telling me not to tie the black wires from the metra harness to the radio black wire?
where should the black wires go from the after market radio and where should the black wires go on the metra plugs?
Old Jun 8, 2012 | 10:42 AM
LosTViet's Avatar
LosTViet
black wire was dead nothing coming from it. you can be like other guy and run a -wire from the gauge to HU or run a wire from chassis( a piece metal in car) so from the metra leave alone and from the HU to gauge or matal
it worked for me ..
now trying to get the HU to fit ...
Old Jun 8, 2012 | 10:51 AM
jtk07's Avatar
jtk07
Question
Just talked to metra
He told me to ground using the larger plug to the HU.
On the smaller plug he said DO NOT use the amp ground!
Got the answer I was looking for I think
it worked for me ..
Old Jun 8, 2012 | 10:59 AM
LosTViet's Avatar
LosTViet
i really am trying to help you out
when i said dead i mean threre was not anything coming from it no positive or negative power just dead .....
when i got the dvd player (HU) used from a friend i did not know it had a bad fuse thats why i said it was fried not meaning i did anyting wrong and it burned up . if you was to get a new HU there should not be anything wrong with your's ...
idk how others are hooking and installing but this worked for me
hope this helped
what do you mean it was dead??
I've read some people do not hook up the grounds on the metra side?
How did it burn up a wire?
Old Jun 8, 2012 | 11:14 AM
jtk07's Avatar
jtk07
Thumbs up
idk how others are hooking are installing but this worked for me
hope this helped
I appreciate all of your help and everyone's help on this site! This is the best 350z forum!!
Old Jun 8, 2012 | 11:15 AM
LosTViet's Avatar
LosTViet
HELL YEA ITS THE BEST SITE !!!!
Old Jun 8, 2012 | 01:41 PM
Patrick250's Avatar
Patrick250
Another thing I ran into using an aftermarket HU with the bose is that my HU preamp outs are 2.5V. It wasn't a high enough voltage to properly drive the bose amp and I had half of the volume that I should have had. I ended up buying a PAC ROEMIS2 and connecting to the speaker outputs of the HU to get the volume back. I had to turn the pots on the PAC all the way up. Some HUs have 4V preamp outs. I've read here that 4 volts is enough.
Old Jun 8, 2012 | 02:29 PM
Patrick250's Avatar
Patrick250
And another thing. The bose audiopilot will drive you nuts if you don't turn it off. Here's the fun part. To turn audiopilot off you need to supply about 7V to the yellow with red stripe wire in connector M39. 0V on this wire turns on the audiopilot. Stupid bose. The yellow/red wire is in one of the connectors that the kit does not address.
I bought a 1/4 watt 10k ohm resistor from Radio Shack (pn 271-1335) to solve this problem. I cut the yellow/red wire away from the M39 connector and spliced in the resistor this way: Red wire -> resistor -> yellow/red wire leading to the bose amp. Problem solved. This supplies appx. 7V to the yellow/red anytime the key is on.
Link to the whole AV section of the 2006 FSM:
http://www.nicoclub.com/FSM/350Z/coupe/2006/av.pdf
And another thing. The amplifier ground of the kit is actually the shield of the rear preamp signal wires to the bose amp. You're going to want to ground that.
One more - you want to connect the blue/white amp turn-on wire to the HU as this turns the bose amp on.
Old Jun 8, 2012 | 03:16 PM
LosTViet's Avatar
LosTViet
Geezzzzzzzzzzzzzzzzzz for real dame bose !!!
I still need help fitting it all back in seems like the bracket is not lining up right or idk lol its just sitting there in the hole
Originally Posted by patrick250
and another thing. The bose audiopilot will drive you nuts if you don't turn it off. Here's the fun part. To turn audiopilot off you need to supply about 7v to the yellow with red stripe wire in connector m39. 0v on this wire turns on the audiopilot. Stupid bose. The yellow/red wire is in one of the connectors that the kit does not address.
I bought a 1/4 watt 10k ohm resistor from radio shack (pn 271-1335) to solve this problem. I cut the yellow/red wire away from the m39 connector and spliced in the resistor this way: Red wire -> resistor -> yellow/red wire leading to the bose amp. Problem solved. This supplies appx. 7v to the yellow/red anytime the key is on.
Link to the whole av section of the 2006 fsm:
http://www.nicoclub.com/fsm/350z/coupe/2006/av.pdf
and another thing. The amplifier ground of the kit is actually the shield of the rear preamp signal wires to the bose amp. You're going to want to ground that.
One more - you want to connect the blue/white amp turn-on wire to the hu as this turns the bose amp on.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
