Radio not working
Old Oct 16, 2012 | 02:46 PM
wahssoccer12's Avatar
wahssoccer12
Default Radio not working
Hey guys, i've got a 2003 z and i took out my pioneer head unit to sell the car, then later decided to keep it. When i put back in the pioneer unit and tested it everything worked fine, but after i put the dash back together it stopped working entirely, no lights, no sound. Checked the radio fuses and nothing was blown, so i took everything apart and found no problems, but if i put the stock head unit back in it works fine. I also noticed that all of the sudden the alert that tells you that your key is in the ignition when the door is open stopped working. any ideas why this might be happening? Seemed like everything was fine until i plugged in my RCA cables, then it stopped working. Thanks in advance.
Old Oct 17, 2012 | 05:48 AM
JERZ350's Avatar
JERZ350
Does everything else work fine? Check all fuses, even the ones not related to the radio. I have had my Mirror Fuse blow when doing my radio, which caused everything in the dash to stop working. You wouldnt think the mirror fuse can cause this, but it can. Also check the ignition wire connection to radio.
Old Oct 17, 2012 | 08:02 AM
JohnG202's Avatar
JohnG202
Sounds like the Mirror Fuse
Old Oct 17, 2012 | 04:28 PM
wahssoccer12
Everything else is working perfectly, just not the radio. If i put the stock radio back in it works just fine, but with the pioneer nothing. I reused the wiring harness that i had before since it was the same radio, so i know that its wired correctly. must just be a broken radio.
Old Oct 17, 2012 | 06:35 PM
sportbiketed's Avatar
sportbiketed
Did you check the fuse on the back of the radio?
Old Oct 18, 2012 | 08:19 AM
wahssoccer12
yeah, the fuse in the back of the radio is fine too. thanks for the ideas guys
Old Oct 19, 2012 | 08:32 AM
richee3's Avatar
richee3
Are you sure the antenna was plugged in all the way? No antenna meant no power for my head unit. I guess the antenna is the ground.
Old Oct 19, 2012 | 08:34 AM
sportbiketed
^That's not good. You need to ground your radio to the chassis.
Old Oct 19, 2012 | 06:42 PM
richee3's Avatar
richee3
I have. No worries there. Just commenting on my Bose head unit not powering on until I plugged the antenna in. Forgot to eject some cd's when I put the Pioneer in, but that's irrelevant. Since there was no ground in my Metra harness and the Bose unit wouldn't turn on until the antenna was plugged in, I'm simply assuming the head unit uses the antenna as a sort of ground. But we all know what happens when we assume.
Old Apr 5, 2013 | 07:23 PM
venture210's Avatar
venture210
damn i got an 06 and i have that same radio, gauge cluster, and small left center gauge not working. all the fuses are fine too
Old Apr 6, 2013 | 03:46 AM
oldschool350z's Avatar
oldschool350z
Yes the antenna must be in.. I learned is it the hard way and I thought my radio is broken. my issue was the mirror fuse it was blown and my radio will not work and neither would my digital gauge
Rowlett
Misc.
Oct 2, 2015 10:38 AM
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
