Dumb Bose auto volume disable?
Old Jan 15, 2004 | 09:04 AM
john.laninga's Avatar
john.laninga
Default Dumb Bose auto volume disable?
Is there an easy way to disable the volume gain based on cabin noise on the Bose installed in the ZR? I'd prefer to twiddle my own volume control....
(basically, gain is too high for my liking)
John
Old Jan 15, 2004 | 01:50 PM
Donald0730's Avatar
Donald0730
It should be a selection when U push the button that adjusts ur bass, treble, etc. I think it's the one after Balance. U can switch it to off or on. I think U want it off.
Old Jan 16, 2004 | 09:00 AM
alienx's Avatar
alienx
If I read correctly, you are speaking of the Audiopilot crap.
There are posts in here about trying to beat the mic with a cheap radioshack part, but I think there was mixed reviews about the actual results.
Old Jan 16, 2004 | 09:55 AM
AndyB's Avatar
AndyB
Default Roadster
Since you have a roadster you have a 2004.
If you go through the options on the radio you can turn off the audio pilot there.
Old Jan 17, 2004 | 03:54 AM
alienx's Avatar
alienx
Damn, I want to be able to turn off mine too!!
Old Jan 17, 2004 | 04:24 AM
john.laninga
Read the manual???!!!???? What a concept! There it is, in Section 4, under radio: Push Audio set button four times, push tune to turn Audiopilot on or off, and it's done.
Maybe I'll curl up with the manual in front of a hot fire tonight and see what other neat things my ZR has to offer me that I don't know about?
Thanks AndyB for bringing it to my attention!
Old Jan 18, 2004 | 07:53 AM
AndyB's Avatar
AndyB
Default 2003
If you have the older system where you can't turn it off you have 2 choices.
You can disconnect the microphone (there are other posts about that). Basically some people have replaced the mike with a resistor which basically tricks the system.
Your other option is to replace the radio with a 2004. With so many people replacing the stock HU with an aftermarket unit you could probably get a 2004 HU free or dirt cheap from someone here. (I am guessing lots of people just toss em).
burglapfd
Dec 6, 2020 01:04 PM
Jambo016
Sep 16, 2016 01:08 PM
Alexreyes
Sep 30, 2015 11:30 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
