two amps where the stock bose sub is? to much heat?
Old Jan 31, 2013 | 08:42 AM
potato's Avatar
potato
Default two amps where the stock bose sub is? to much heat?
I am getting ready to install a JL sound system in my car which will include a JL JX500/1D and a JL XD 400/4 amp. I would like to put these both behind the driver seat inside where the stock bose sub is. will this generate to much heat in a small area for me to run this setup? would i need some kind of fan hooked up on the backside of the speaker cover?
any input appreciated. thanks
Old Jan 31, 2013 | 09:14 AM
iideadeyeii's Avatar
iideadeyeii
You will be fine.
Old Jan 31, 2013 | 09:15 AM
Edmonton 350z's Avatar
Edmonton 350z
The sub panel is vented, so shouldn't be a problem. I have two behind the storage panel on the passenger side and never had a problem. The storage box cover had been changed to the vented sub cover on that side.
Old Jan 31, 2013 | 09:48 AM
beezee's Avatar
beezee
That place is not sealed. lots of cavities that connect to the trunk area and rear speaker hump area. even without vented cover you should be fine
Old Jan 31, 2013 | 10:08 AM
potato's Avatar
potato
awesome, looks like thats where ill be putting them
