FLIR real heat seeking Night Vision on g35 (install)
Bought a FLIR night vision camera for a 99-03 Cadillac Deville, install a 5" monitor above my CD player and install the camera behind the grill. Awesome thing was I didn't have to drill a hole in the grill for the lens, it just happens so that when I installed the camera lens happened to be between the two horizontal fins on the grill and it can see between them without me having to mod the grill.
Cadillac camera is pretty expensive, usually sells for $800-1200 on ebay but I found one locally for $300. Be careful when buying the camera, there are 2 versions. 2nd gen version is smaller and better. 1st gen version had a bad seal and water would get in it and it would rust out all the electronics inside (don't buy). I've had four 2nd gen version cameras and they all worked fine.
Here is a video of the camera working: ►►► g35 Flir Night Vision ◄◄◄<br><br>
VIDEO WORKS NOW: ►►► g35 Flir Night Vision ◄◄◄ You can install the 5" lcd right above your cluster and it would be like a HUD. And Cadillac used the camera as night vision on the Cadillac too. At night you can see up to 1/4 mile in front of you and anything with heat is pretty easy to spot look:<br><br>
