No sound from speakers....help please
Old Apr 12, 2013 | 10:07 PM
akuma69's Avatar
akuma69
Default No sound from speakers....help please
Hey guys I have a problem with my car sound.
I'll get straight to the point.
Have a 2005 350z with stock bose system. The speaker output connector behind the radio needs to be replaced (i broke it thats why. Kicking myself ).
I bought new connector from ebay and connected it up with the wires going to the speakers. I basically matched the colours best I could.
Here are the connections
(New connector cables behind radio - speaker cables into the car)
purple wire - Pink wire
purple black - pink/red -
green - green
green/black - green/black
blue/white - blue
white/black - grey
I connected this all up but I dont hear anything from the speakers anymore. But radio does turn on.
is there a amp fuse in the trunk that I might have blown by shorting the speaker wires?
im pretty sure i wired them up correctly. I'll attach pictures soon.
Old Apr 12, 2013 | 10:10 PM
akuma69's Avatar
akuma69
Attached Thumbnails No sound from speakers....help please-back-of-radio-1.jpg   No sound from speakers....help please-back-of-radio-2.jpg
Old Apr 12, 2013 | 10:24 PM
akuma69's Avatar
akuma69
Attached Thumbnails No sound from speakers....help please-speakers-cables-coming-from-car-1.jpg   No sound from speakers....help please-speakers-cables-coming-from-car-2.jpg   No sound from speakers....help please-help-for-the-harness.jpg
Old Apr 12, 2013 | 11:27 PM
akuma69's Avatar
akuma69
update: i checked the 15A fuse on the drivers side panel and it looks all good.
Would there be another fuse in the amp which is in the trunk?
Old Apr 13, 2013 | 04:24 AM
oldschool350z's Avatar
oldschool350z
Check the mirror fuse . Thus was blown in my z
Old Apr 13, 2013 | 05:20 AM
akuma69's Avatar
akuma69
the heated mirror fuse?
Old Apr 13, 2013 | 07:07 AM
oldschool350z
It was 10A fuse near the driver side kick panel. My radio wouldn't work until I replaced the fuse.
Old Apr 13, 2013 | 07:24 PM
akuma69's Avatar
akuma69
The radio works fine. It turns on and stuff. Just no sound from speakers. So im guessing its the amp.
Any other ideas?
Old Apr 13, 2013 | 09:30 PM
akuma69's Avatar
akuma69
hey i just checked the outputs from the radio. It all looks fine. The radio is fine. Used earphones to check the audio output.
"green and green/black" wires output from radio works fine. Could hear music clearly in earphones.
"pink and pink/red" wires output from radio works fine. Could hear music clearly in earphones.
the white/black and blue/white cable showed 12 volts across it. So that seems fine too.
I think something wrong with the amp then?
I took the amp out but there is no damn fuse on it!
what now guys?
Old Apr 13, 2013 | 11:50 PM
akuma69's Avatar
akuma69
https://my350z.com/fo...rking-av-10.jpg
When I make contact with the 9V battery, no sound is heard from speakers. These wires are the ones that go INTO the amp.from the Head Unit. So the actual arrangement was this...
speaker -> amp ---> wires -> 9V Battery
Could not hear anything. I am sure the speakers are fine because they wont ALL die at once. The HU works fine too (checked audio outputs). Only thing between the HU and speakers is the bose amp.
I really think the amp is gone.
I opened it up and saw a diode thing that didn't allow current through either way. So I think the amp is gone. I couldn't find a fuse anywhere. Or is the fuse for it somewhere else?
Whats the best places to buy a cheap bose amp?
Old Apr 14, 2013 | 04:24 AM
oldschool350z
Hmm I also agree I don't think all the speakers would go out at once.
To find a cheap Bose amp look here in the for sale section or eBay,
Old Apr 14, 2013 | 06:13 AM
K51's Avatar
K51
Sorry boys, but there is only one correct way, not "best I could". And why on earth would anyone wire 9VDC to the input side of an amp? What's the theory there? Hopefully, this has been a learning experience, on what not to do.
Old Apr 16, 2013 | 06:03 AM
CuzD2B's Avatar
CuzD2B
Whats the best places to buy a cheap bose amp?[/QUOTE]
I dont think there is a fuse for the stock amp itself. I did some digging around... try this "If you open up the amp itself, which is enclosed in a metal enclosure, you'll see this gray box on the circuit board. I made my sub go out first on purpose (by increasing bass) and then applied pressure to see if that indeed would correct the problem (while the amp was taken apart but still connected). Lo and behold, it actually solved the issue" <--- known to fix connectivity issues...
If that doesnt work just buy a new amp they are pretty cheap on ebay (Bose).
Old Apr 19, 2013 | 10:19 PM
akuma69's Avatar
akuma69
If that doesnt work just buy a new amp they are pretty cheap on ebay (Bose).[/QUOTE]
I didnt quite get that. So i just apply pressure to the gray box. Ill try that.
Old Apr 22, 2013 | 12:55 PM
Lucky736's Avatar
Lucky736
I didnt quite get that. So i just apply pressure to the gray box. Ill try that.[/QUOTE]
Anyone have a ny pics etc of this, or confirmation. Radio started acting up yesterday, sigh.
Old Nov 6, 2019 | 10:06 AM
Kerry Whittle's Avatar
Kerry Whittle
Default amp reset itself
My system showed the same the same symptoms as the rest except: my amp reset itself somehow.
Being disgusted I let my car sit for a couple days. Went to crank it and the battery was dead, nothing but clicks from the starter. I used my jumper box to start it, tried the radio and it worked! Go figure
Battery has been ok ever since.
Old Nov 6, 2019 | 10:07 AM
travlee's Avatar
travlee
Master
6.5 year dead thread
Old Nov 6, 2019 | 06:12 PM
akuma69's Avatar
akuma69
OP here guys! i had fixed my problem back in 2013. Sorry did not post the solution here.
I fixed the problem and posted on Australian website zclub.
Here is the thread with solution.
http://zclub.com.au/forums/index.php...rshelp-please/
I'll post the solution here as well.
The issue was not the amp. It was incorrect wiring.
And this colour coding (below) that i found all over the internet as well...
got this from http://www.modifiedlife.com/car-stereo-radio-wiring-diagram-2005-nissan-350z/
Radio Constant 12V+ Wire: Yellow
Radio Switched 12V+ Wire: Light Green
Radio Ground Wire: Chassis
Radio Illumination Dimmer Wire: Red/Blue
Radio Antenna Trigger Wire: Green/White
Radio Amplifier Turn On Wire: Green/Yellow
Left Front Speaker Wire (+): Blue/Red
Left Front Speaker Wire (-): Black/White
Right Front Speaker Wire (+): Yellow/Red
Right Front Speaker Wire (-): Red/White
Left Rear Speaker Wire (+): Light Green/Red
Left Rear Speaker Wire (-): Black/Yellow
Right Rear Speaker Wire (+): Blue/Orange
Right Rear Speaker Wire (-): Black/Pink
..is WRONG! none of the colours matched what i saw behind the head unit.
I guess those are for overseas model Z, not the australian one.
I found the australian one and got the wiring right and now music plays!! my amp wasn't dead!
Here are the Aus diagrams. As you can see the colour codes are different to the ones provided above
Old Nov 6, 2019 | 09:12 PM
813_350Z's Avatar
813_350Z
Glad to hear you got it working, OP. Thank you for returning and posting the solution. It will come in handy should others have the same problem.
Old Nov 18, 2019 | 06:48 AM
Afia Odo's Avatar
Afia Odo
Default Next time visit slutmum.com to get it repaired fasr
Slutmum
Steps On How To Date A MilfNude mom - Mom had sex with daughter's boyfriendNude mom - Sex with mom becomes creampieNude mom - Wild hot sex with hot mom
