Keyfob programming
Old Jan 24, 2004 | 11:08 PM
CopperZ's Avatar
CopperZ
Default Keyfob programming
I have an extra key fob that i have from my old Infiniti, that i want to program to work on my Z. Who knows how to do that?? the dealer wants $40 just to do this.
Old Jan 25, 2004 | 04:36 AM
mgk65's Avatar
mgk65
A little more detail, this one worked for me...
1. Get in the vehicle.
2. Close and lock all doors utilizing the driver's power-door lock/unlock switch.
3. Insert and remove the ignition key more than six times within a 10-second period (at a rate of one insertion/removal cycle per second). Don't rush the process, and be sure the key is completely withdrawn from the ignition-key cylinder each time it's removed.
4. Turn the ignition to the ACC position and press any button on the remote one time. The hazard lights should flash twice, letting you know your mission is a success.
If you were going to program more than one remote, you'd simply unlock and lock the doors once again with the driver's switch and press the one button, one time, on the second remote. The procedure is completed by turning the ignition off, unlocking with the driver's switch, and opening the driver's door.
Old Jan 25, 2004 | 09:58 AM
CopperZ's Avatar
CopperZ
Its not working, after taking the key in and out about 7 times the lights blink and then i turn it into acc and hold a button on the fob, but nothing happens.
Old Jan 25, 2004 | 07:24 PM
mgk65's Avatar
mgk65
The door has to be closed and locked.
Don't insert and remove the key too fast.
Here's the page from the Tech Manual.
http://www.courtesyparts.com/Merchan...ntry_Instr.gif
Detailed Image
Cleaning & Detailing
Sep 18, 2015 11:43 AM
Detailed Image
Sep 16, 2015 04:56 AM
abz123
Feb 6, 2003 01:19 PM
Todd
Sep 7, 2002 07:14 PM
Todd
Aug 24, 2002 08:31 AM
