Tilt Sensor vs. Motion Sensor
Old Aug 11, 2013 | 05:03 PM
hearts98jm's Avatar
hearts98jm
Question Tilt Sensor vs. Motion Sensor
Not sure which to get and want the input of those who have tilt sensors or motion sensors on their Zs. Thank you.
Old Aug 11, 2013 | 09:17 PM
samsniss350z's Avatar
samsniss350z
Are you writing about the RACELOGIC GPS dataloggers? These show drift angle, braking performance, 0-60mph time, top speed, G-Force, acceleration and a whole host more? These are used by 99% of the worlds car manufacturers. Try www.racelogic.co.uk for more info
Old Aug 12, 2013 | 07:04 PM
rebelscum's Avatar
rebelscum
He is talking about sensors for an alarm system. Tilt is only needed if you really are concerned someone will try to jack your car up and steal your rims... But I'm pretty sure low imact jacks (like the scissor jack that comes with most cars) won't set it off anyway. Motion sensors are hard to adjust and give false alarms most of the time. That being said, as long as you have even ONE sensor port (including one currently taken up by a shock sensor), you can hook up both on that one if you wanted
Old Aug 12, 2013 | 08:15 PM
Bhirst's Avatar
Bhirst
Using a proximity sensor works the best however like said above they do false a lot of not adjusted properly. If you are installing it yourself make sure it is in the center of your car and give yourself plenty of time while adjusting it. Nothing is more annoying than an alarm system that falses a lot
Old Aug 12, 2013 | 08:28 PM
hearts98jm's Avatar
hearts98jm
Thanks for the responses, I just ended up getting a viper with shock sensor. Works great now. And it's she not he lol.
Old Aug 16, 2013 | 11:18 AM
Suwaidi's Avatar
Suwaidi
I've read that the motion sensor gives false alarms, but the tilt sensor might be useful in case you're getting towed, or wheels getting stolen.
Old Aug 16, 2013 | 10:47 PM
DarkCreep's Avatar
DarkCreep
Id definitely go with a tilt sensor since its harder to steal these cars through hotwire, its easier to just tow it.
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
350Z Project X
Oct 17, 2015 05:16 PM
