2003 Factory Navigation
Old Aug 13, 2013 | 04:32 PM
vernors79's Avatar
vernors79
Default 2003 Factory Navigation
My factory navigation is not getting power. Where might I find the fuse or trouble source of my problems. Please help, getting frustrated.
Old Aug 14, 2013 | 09:06 AM
Suwaidi's Avatar
Suwaidi
There's a fuse box behind the battery, and on the driver side near the left panel (your feet).
Old Aug 14, 2013 | 04:37 PM
Spike100's Avatar
Spike100
Hi vernors79,
If your unit is not getting power, it could be a fuse; but if that is the case, you are probably dealing with a bigger problem. A blown fuse for an A/V device often means there is a problem with the device.
I would check the power wire to the unit (you will need to open the center console). You can test the power line; or test the device itself by running a 12 volt line from a power converter. I like testing devices with a known-good power source. That way you “know.”
--Spike
Old Aug 14, 2013 | 09:19 PM
bealljk's Avatar
bealljk
I have an OEM navigation (also out of a 2003) that I took out of my car if you need spares/replacement…Everything works fine. I've gutted my car bc I'm bat-**** crazy and have a desire to go fast, and no extra 4lbs is gonna slow me down!!!
Old Aug 14, 2013 | 11:04 PM
DarkCreep's Avatar
DarkCreep
I remember when I used to be like this, then I grew up and realized a few pounds shaved wont get me to work any faster.
Old Aug 15, 2013 | 03:58 AM
vernors79's Avatar
vernors79
Thanks guys, got it to light up anyway, but the monitor does not come on or if there is a disk in it it will not eject or take a disk if there is not. The micro switch behind the door has a wire broken off. From what I have read its not worth sinkin any real amount of money into, so I think I'm gonna pull it all out and just put a cubby in the dash.
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
