In car Pc photo's
Old Jan 28, 2004 | 12:37 PM
CopperZ's Avatar
CopperZ
Default In car Pc photo's
Herer is the Lilliput TouchScreen case opened up. I took out the LCD screen.
CopperZ's Avatar
CopperZ
here it is in the car
Old Jan 28, 2004 | 12:38 PM
CopperZ's Avatar
CopperZ
here is the start up screen
Old Jan 28, 2004 | 12:40 PM
CopperZ's Avatar
CopperZ
here is the interface at work, 1st is the mp3's 2nd is the dvd's/cd's 3rd is the playlists 4th is the nav
Old Jan 28, 2004 | 12:42 PM
CopperZ's Avatar
CopperZ
big tymers vid.
Old Jan 28, 2004 | 12:44 PM
CopperZ's Avatar
CopperZ
shut down menu. laptop is under the seat.
Old Jan 28, 2004 | 12:46 PM
CopperZ's Avatar
CopperZ
This is how easy it is to control the mp3's. Sorry it’s blurry. If any one wants to buy the touch screen let me know. $310 shipped.
Old Jan 28, 2004 | 07:26 PM
z327's Avatar
z327
Looks good....but get some windex
Old Jan 29, 2004 | 01:39 PM
bshockley's Avatar
bshockley
Bad ***. You are using the Media Engine Skin I made. I was just messing around one day and decided to make it. Anyway, i am glad someone is getting a good use out of it. I don't have an in car PC.
Old Jan 29, 2004 | 02:01 PM
ares's Avatar
ares
Veteran
its more or less unavoidable when your talking about a touch screen.
Old Jan 29, 2004 | 09:23 PM
genbo's Avatar
genbo
Curious what nav software you are using? Does the data base cover Canada?
Thanks, Perry
Old Jan 30, 2004 | 12:40 AM
Grommit's Avatar
Grommit
What are the specs of that screen? What resolution does it support? And what inputs does it have?
I am very interested in buying it. Is the picture sharp? When you play DVD's on it, does the picture blur between frames? does the picture look grainy? Can you post a higher quality pic of the screen???
Old Jan 30, 2004 | 11:40 AM
CopperZ's Avatar
CopperZ
Thanks for the skin I love it. Plus I have the copper z so it looks like its just made for my car. My only complaint about the skin is that you don’t have outside apps button and the shutdown button for the whole computer. But other then that I love it. Good job. Oh and get a car pc you’ll love it.
Old Jan 30, 2004 | 11:44 AM
CopperZ's Avatar
CopperZ
Thanks, Perry
I did not get the Nav yet. But I am going to buy it soon. It’s a delorme earthmate gps. http://www.delorme.com/earthmate/configlaptop_info.asp ] http://www.delorme.com/earthmate/configlaptop_info.asp [/URL]
Old Jan 30, 2004 | 12:04 PM
CopperZ's Avatar
CopperZ
LCD screen size: 7 inches digital (15.4 x 9.2 cm)
Ratio: 16:9 wide TFT screen, high resolution: resolution: 2,400 x 480 = 1,152,000 pixels
Support computer display resolution up to 1024 x 768
Multi Video system: PAL/NTSC
VGA and 2 composite Video inputs plus 1 Audio input
Touchscreen display (USB interface)
Credit card size IR remote control
Full function OSD control (Multi-language)
Audio output: Speaker built-in & earphone jack
Video input signal: 1.0Vp-p, composite video
No radiation (better for eyes protection)
Compact slim panel: 18.7 x 12.5 x 3.3 cm only
Computer display/S-video/DVD/VCD/Security system/Navigation system compatible, (Rear view camera connectible)
Mount type: Dash board
Power input: DC 12V, Power consumption: 9W
Jacks
AC in
Head phone
USB port
Accessories
1. 1 pc VGA / USB 2-in-1cable
2. 1 pc A/V cable
3. Remote control with battery
4. Touch pen
5. Switching AC adapter
6. Car 12V adapter
7. User Manual
8. Installation CD (touch screen) with drivers for DOS, windows 95, 98, NT, 2000, ME, and XP
The picture is very sharp, it looks a lot better then my laptop screen. I did not have a chance to play dvd’s on it because my laptop does not support dvd’s. I only played vcd movies and there was not freezing up or anything. Movies look whole lot better then they do on the laptop screen.
The only problem that I noticed is that it flickers when I first start it. This is hard to see and you can only see it when you look really hard at the screen. But then the flickering goes away. I think it just needs to worm up a bit because it did not flicker when it was in my house. And its 2 degrees outside right now so im guessing that’s why.
The major problem that I found is that when it’s really sunny outside its a little hard to see the screen. But then again I have no tints and that happens to every lcd screen. I will take some pic’s when I get my car back.
Old Jan 30, 2004 | 03:16 PM
mdmike's Avatar
mdmike
Copper,
Excellent Job....
Looks like the top and bottom on the screen is cut off in the picture. Also what did you do with the controls for the display. Did you reroute them?
I have been thinking about putting a laptop in my car or a PS2/Xbox for DVD play back but I really haven't desided on a screen yet.
Old Jan 30, 2004 | 03:20 PM
MannishBoy's Avatar
MannishBoy
I read a lot of posts on this screen several weeks ago over at mp3car.com, and all the defects have me scared to death of the thing. I wish I could get over my nervousness, and I'd get one
Old Jan 30, 2004 | 03:58 PM
CopperZ's Avatar
CopperZ
The top is not cut off. The bottom seems like it is, only on the pictures though because that plastic piece is in the way of the camera and I was holding the camera low.
The controls are under that same plastic piece and I control it with the remote. I did not even have to drill a hole for the signal to go thru because there is a little hole in there already for the door lock.
MannishBoy, I read the carMp3 reports as well, I heard nothing but good things about it. there is only a 3% defective rate on lilliput screen’s. Please let me know where you saw the reports.
Old Jan 30, 2004 | 04:18 PM
MannishBoy's Avatar
MannishBoy
Here for instance.
I went through about 3 pages of posts, and found several others with issues from flickering to bad pixels to touchscreens not working.
*shrug*
Old Jan 31, 2004 | 06:50 AM
aalzuhair's Avatar
aalzuhair
Hi CopperZ,
Did you use the instrument panel lid for navigation sys or the lid for non navigation system?
Thanks,
Az
