Need help asap: Wiring problem
Old Feb 18, 2014 | 02:04 PM
joelxsweat's Avatar
joelxsweat
Default Need help asap: Wiring problem
2004 350z Touring Roadster
has stock bose sound system and stereo
I was removing the head unit because a cassette got stuck in there and when I was putting it back together the colored wires all fell out and I do not know which color goes where
anybody know?
Old Feb 18, 2014 | 04:51 PM
DarkCreep's Avatar
DarkCreep
Youre screwed. Good luck OP.
Next time, push down on the release lever before pulling.
Old Feb 18, 2014 | 04:53 PM
nscheuermann's Avatar
nscheuermann
That is a very sh!tty problem
Old Feb 19, 2014 | 06:00 AM
mnd7775's Avatar
mnd7775
Your best bet would be to look through the FSM, its not going to be fun, but its doable. Find the connector number in there(usually letter followed by two digit number ie B20) and then look at the schematic and figure out the color and correspond it to the pin/position number on the connector.
Old Feb 19, 2014 | 06:35 AM
Syner's Avatar
Syner
I seriously lol'd when I saw this.
Old Feb 19, 2014 | 08:20 AM
wbama387's Avatar
wbama387
Thats going to be a nightmare. Plus all the tabs, for each wire, are probably broken now.
Old Feb 19, 2014 | 05:48 PM
Tsquared's Avatar
Tsquared
It happens, OP. That particular plug can be a bit@h. MND7775 gave you the only actual answer to your problem.
Old Feb 19, 2014 | 08:08 PM
Syner's Avatar
Syner
Really? Thanks for the heads-up, Captain Obvious... or is it Oblivious?
Old Feb 20, 2014 | 01:27 PM
Tsquared's Avatar
Tsquared
If you want to troll, stick to the ricer threads.
Old Feb 20, 2014 | 01:29 PM
Syner's Avatar
Syner
Sure thing, Powder Puff.
Old Mar 11, 2014 | 11:54 AM
joelxsweat's Avatar
joelxsweat
I have tried with no good results. I give up, I will just have to drive in silence and boredom.
Old Mar 11, 2014 | 12:44 PM
iideadeyeii's Avatar
iideadeyeii
Google search fail
1 . black ( front left hand speaker - )
2. white (front left hand speaker + )
3. red ( front right hand speaker - )
4. green ( front right hand speaker + )
5. green /white ( antenna signal )
6. yellow ( perm 12v + )
7. red/yellow ( illumination signal )
8. red/blue ( lighting switch )
9. shield
10. blue/green ( 12v + switched )
Old Mar 11, 2014 | 12:49 PM
jhc's Avatar
jhc
General & Tech Moderator
Joel,
Might be lot easier to call local scrapyards, see if they have a Z.
Take pic of harness, or simply buy it.
Good luck!
Old Mar 11, 2014 | 01:50 PM
92K1500's Avatar
92K1500
This.
I doubt the wires will stay in the connector anymore.
Old Mar 12, 2014 | 08:33 PM
qikz's Avatar
qikz
Originally Posted by 92K1500
This.
Yea they do, I've just done the same thing with the smaller plug. Double checking now for colour codes as they are different from pic (I have 05 anniversary)
Uriyo_
Sep 8, 2021 08:46 AM
