Anyone have a link to a DIY /How to - For Installing Steering wheel Buttons
Hey guys,..
I have searched, and for whatever reason I can't find the guide I've run across before..
If it matters this is for a 2008 350Z Base Model,..
I am about to Tune my car.. and need the Cruise and Set buttons working to change maps.. I have them here, just need to install them. I know you need to remove the air bag to do so, so I'd like a guide on it to glance over before I start.. I've already grabbed the Torx bit set, and have the controls.. I just would rather glance at something before I get started.
I know one exists as I've seen enough to know that I need the Torx bit(s) to remove some parts.. I just can't find it again.
Any help? links? etc..
These are the buttons -- They go on both sides.. to replace the blank grey panels I have now... (They just plug into the factory harness as even the bases have them built in). (The flash tune will enable the cruise).
I have the Pedal switches in,.. and am in the process of flashing the ECU with Uprev/Osiris via R/T Tuning.. No Cluster yet, but things should work fine without the cluster just won't see the "Cruise/Set" lights until I obtain one.
http://www.courtesyparts.com/25550n-...4_715_751_755&
I know it's fairly straightforward,.. but.. I would,
Appreciate any links, help, etc.
Thanks,
Thanks,
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
