Running Power to Amp
Old Apr 8, 2014 | 06:38 AM
GoneFishen's Avatar
GoneFishen
Default Running Power to Amp
For those of you running big amps, did you source power direct from the battery, and if so how did you run the wire?
Old Apr 8, 2014 | 06:56 AM
iideadeyeii's Avatar
iideadeyeii
Drilled a hole near battery tray through fire wall an ran through center console.
Old Apr 8, 2014 | 07:04 AM
92K1500's Avatar
92K1500
Don't drill holes!
There is a big *** grommet in the corner of the battery area under the plastic panels. I just cut a slit in it and ran the wire through it. It drops down in the passenger kick and you can hide the wire behind the kick panel and under the carpet.
I have a run of 1/0 ran to my back battery and I'm grounded to the baby seat attaching bracket doodad.
Old Apr 8, 2014 | 07:08 AM
92K1500's Avatar
92K1500
And here is the view from under the dash. You can see the red 4AWG coming down out of the dash. If you lay in the floor and look up you can see a straight shot to that grommet.
Old Apr 8, 2014 | 09:18 AM
dcains's Avatar
dcains
http://liljerk.morpheus.net/350Z/firewall/
Old Apr 8, 2014 | 09:22 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by 92K1500
+1, right here. Make sure and lube your power cable up with soap so it'll glide through easily.
OP, how big of an amp are you talking about anyway?
Old Apr 8, 2014 | 11:01 AM
iideadeyeii
I drilled the shiz out of it!! Weight reduction yo
Old Apr 8, 2014 | 11:56 AM
Spike100's Avatar
Spike100
Jesse Pinkman sighting?
Old Apr 8, 2014 | 01:21 PM
92K1500's Avatar
92K1500
He didn't say b¡tch so I'm thinking it's just a poser.
Old Apr 9, 2014 | 05:18 AM
VO...'s Avatar
VO...
Administrator
OP, are you going to ever come back or was this just a one time post hitter quitter?
Old Apr 9, 2014 | 05:32 AM
92K1500's Avatar
92K1500
He's gone fishen and forgot about putting amps in his car....
Old Apr 9, 2014 | 07:26 AM
VO...'s Avatar
VO...
Administrator
Old Apr 9, 2014 | 10:54 AM
jdmfetish's Avatar
jdmfetish
should be no problem there
I have 4 runs of 0 awg thru there
LUBE
Old Apr 9, 2014 | 11:09 AM
92K1500's Avatar
92K1500
LUBE
Pics of install?
Old Apr 9, 2014 | 12:41 PM
VO...'s Avatar
VO...
Administrator
Pics of install?
+1.
I had a heck of a time getting one 0 awg through there...
Old Apr 9, 2014 | 01:27 PM
92K1500's Avatar
92K1500
Originally Posted by vo7848
+1.
I don't remember having trouble running my 1/0. But I am just curious as to what he has pulling that much current.
I'm just running a 1000w and a 100x4 so a single run of 1/0 is probably overkill but I did it anyways.
I actually started my car off the rear battery for a week or so when the ground cable came off my front battery.
Old Apr 10, 2014 | 06:50 AM
VO...'s Avatar
VO...
Administrator
It's good to have more than enough, than too little. Ball park I'm pushing about 1800watts with both amps combined. I actually needed to incorporate a 1 farad capacitor, new battery, and do the "Big 3" grounding upgrade in order for the amps to have enough juice to not drain from the rest of the car. Before the extras, my headlights and dash lights were dimming...
Old Apr 10, 2014 | 07:24 AM
jdmfetish's Avatar
jdmfetish
have run numerous amps
2 saz 1500
2 saz 2000
1 saz 3500
1 saz 4500
2 gp 3000 d
1 rf t20001 bd
1 rf t40001 bd
numerous 2 ch and 4 ch
at the moment 1 saz 2000 and a sax 100.4
dd mids and highs
dd 15" 9500 @ 30 hertz sub up slot port to the driver rear corner
stinger spp 1200
250 amp alt
Old Apr 10, 2014 | 07:57 AM
VO...'s Avatar
VO...
Administrator
2 saz 1500
2 saz 2000
1 saz 3500
1 saz 4500
2 gp 3000 d
1 rf t20001 bd
1 rf t40001 bd
dd mids and highs
stinger spp 1200
250 amp alt
Good job.
Now how about that pic? It's not that I doubt you. It's that I want to see it. I can't imagine how tough it was to stuff all 4 in there...
Old Apr 12, 2014 | 03:48 AM
GoneFishen's Avatar
GoneFishen
Thanks for the advice and the pics, outstanding. I'm running 6 awg wire to a 1000W amp and glad to hear I don't have to drill a hole in the firewall.
