Will this sub and amp work together?
Old Jul 13, 2014 | 10:25 AM
hookah's Avatar
hookah
Default Will this sub and amp work together?
Hey guys. This isnt for my Z and I am new with subs and stuff.
Will these two work fine?
Click for amazon subwoofer link Click for amazon subwoofer link
Click for amazon amp link Click for amazon amp link
I know this subwoofer isnt the best, but it should be fine for me.
Thanks.
Old Jul 13, 2014 | 10:41 AM
92K1500's Avatar
92K1500
Those subs are rated for 400w each and the amp puts out "700w" per channel at 2 ohms.
Depending on how accurate that amps rating is, which it's probably not close, you'll just have to turn it down a little to keep from blowing the subs.
Old Jul 13, 2014 | 11:03 AM
Z1NONLY's Avatar
Z1NONLY
From the info I could find, it takes two 25-amp fuses. With 15v from your alternator and 100% Efficiency from the amp, it will produce ~750 watts total. Of course, both 15v and 100% efficiency are not going to happen, so you will not overpower the subs. The amp also makes full power at 2 ohms stereo, so connecting it to 4 ohms will probly cut your output by another 40% or so.
The good news: They will "work" together.
The bad news: You will not get the full potential from either the amp or the subs with this configuration.
Old Jul 13, 2014 | 12:36 PM
92K1500's Avatar
92K1500
Originally Posted by Z1NONLY
From the info I could find, it takes two 25-amp fuses. With 15v from your alternator and 100% Efficiency from the amp, it will produce ~750 watts total. Of course, both 15v and 100% efficiency are not going to happen, so you will not overpower the subs. The amps also makes full power at 2 ohms stereo, so connecting it to 4 ohms will probly cut your output by another 40% or so.
He could hook each sub to the amp, one per channel at 2 ohms. Then it would get max power from it.
Or bridge at 4 ohms. Either way you get the same power. I personally don't like running anything in series so I would do stereo @2.
I found sonicelectronix pics showing 2 20A fuses, but PA's website has 2 25A's...
Also, our cars are lucky to see 14-14.2v during the summer (mine is at least) so that drops the theoretical 100% efficiency power to either 560-568 or 700-710 watts.
Then factor in efficiency. I'm going with best case scenarios. 14.4v, 50A fusing, 90% efficiency Class D would put you at 648W.
So your "2000 Watt" amp just turned into a 650W amp.
Funny how that works.
Old Jul 13, 2014 | 01:37 PM
Z1NONLY's Avatar
Z1NONLY
I misunderstood the description to mean two 4-ohm woofers in one box. If they are dual voice coil speakers that have two 4 ohm coils each, then yes each one can be wired for 2 ohms.
Old Jul 13, 2014 | 03:56 PM
hookah's Avatar
hookah
Thanks a lot for the info guys.
Well I realized that the damn subwoofer is too big for my trunk. So I need to go with a single one sub. I am going to look around for a single sub.
Old Jul 14, 2014 | 07:38 PM
hookah's Avatar
hookah
Ok how about this setup?
Subwoofer:
Click here Click here
Amplifier:
This This
this this
box:
this this
this this
, depending on if I need a vent or not. Do I?
Thanks a lot guys!
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
