New install questions
Old Apr 22, 2016 | 11:24 AM
jlb's Avatar
jlb
Default New install questions
Hey all. I really hate posting, because I don't want to seem like a moron. But Im not finding my answer, even tho I know its in here somewhere. So, I installed a new headunit. Kenwood DDX373bt. I havent really played with it much yet, but the main issues I have are that I can hear the engine through the radio, and the fm reception is garbage. Bad ground, right??? That's what im thinking anyway. Unless im overlooking something.
Also, I bought a Sundown SD-3 10D4 and had a custom box built. I powered it with PPI i350.2. A 350w amp. For some reason, I have to turn the gain and all adjustments all the way up, for it to slam. Doesnt sound right, right??
Any help appreciated. I will be working on this likely tomorrow. Thanks guys.
Old Apr 22, 2016 | 12:00 PM
rawgarage's Avatar
rawgarage
just pull up on an audio installer... takes him 20 mins max...
Old Apr 22, 2016 | 02:56 PM
dcains's Avatar
dcains
Sounds like a bad ground, or maybe a ground loop - at least that's the engine noise. As for the FM, did you hook up the wire that provides power to the car's antenna amplifier? I don't recall which one it is, but you can use the amp turn-on lead from the headunit to provide power to it.
As for the other stuff, I have no idea.
Old Apr 23, 2016 | 05:23 AM
jlb's Avatar
jlb
Great thanks. I will check into all that today. I will keep messing with the settings and whatnot for the amp and receiver, I'm sure it just needs to be tuned properly. Thanks again!
Old Apr 23, 2016 | 07:17 AM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Did you remove all the bose equipment and make a bon fire with it? If you are still using any of the bose equipment your going to run into issues like you seem to be...
Old Apr 23, 2016 | 04:28 PM
beezee's Avatar
beezee
As said above you need to power up the antenna. Connect it to your amp turn on wire so it turns on and off with your amp. Your after market wire harness instructions should tell you which wire.
For the whine from your engine check grounds first and don't run audio wires close to power wires. If all fail install ground loop isolator
Old Apr 25, 2016 | 02:17 PM
jlb's Avatar
jlb
Pretty much, haha. Not using any Bose stuff now.
Yea, i'll have to do that. Didn't have time to check that this weekend. Been too busy with my honey do list. Thanks for the suggestions guys. Appreciated.
-Jared
zacav8r
May 2, 2016 05:42 AM
Austin2999
Apr 26, 2016 08:29 AM
2fasst
Suspension
Apr 21, 2016 08:26 AM
