So confused?! Can I not power new speakers directly from the head unit?
Old Oct 25, 2022 | 03:34 AM
D8V3's Avatar
D8V3
Default So confused?! Can I not power new speakers directly from the head unit?
Hi All,
I am very surprised I have never posted here before as I have had my Z for 7 years now and have just been skulking in the background reading all the comments but not contributing and for this I apologise. I have come across a question I cant find an answer for, and if the answer is out there its buried inside another question or thread.
My question is - is it really that hard to swap the head unit from a Bose system and have after market door and rear speakers powered from the head unit itself?
Ultimately that is what I want to achieve. Are the door and rear speakers powered by the bose amp or does the bose amp just do the sub? I want to replace the front and rear speakers but I've read there is a problem with the impendence.... is this just for swapping speakers with the standard Bose HU? or with an after market HU too?
Many many years ago I followed the below awsomely helpful guide and fitted the same exact stereo in the exact same way but now I want to swap out the speakers. The Pioneer SPH-DA120 I have is putting out 4 x 50w, is there no way to utilize this? I'm no stranger to running new speaker wire through doors to amps ect as I did that in my S2000 many moons ago but I dont want to if I dont have to.
https://www.350z-uk.com/topic/106961...inks-to-parts/
If anyone is able to shed any light on powering new door and rear speakers from the HU itself I would be eternally grateful or if its an "amp or nothing" deal then I guess I best just dig deeper in the pockets.
Thanks all.
Old Oct 25, 2022 | 03:57 AM
travlee's Avatar
travlee
Master
simple answer, is rewire the speakers directly to the headunit bypassing all the bose items
Old Oct 25, 2022 | 04:04 AM
D8V3's Avatar
D8V3
Heya thanks for the reply.
So short or snipping up the loom/harness out the back of the stereo and running these new wires directly to the speakers its a no? and I am guessing for this fact alone, people are thinking "Well if I have to run new wires anyway I may as well do it from a decent amp and reap the benefits?"
Old Oct 25, 2022 | 04:15 AM
travlee's Avatar
travlee
Master
bose speakers and amps run at a lower ohm than aftermarket, the only way to make is sound right is to bypass everything
Old Oct 25, 2022 | 04:58 AM
Heel Til I Die's Avatar
Heel Til I Die
If you're changing out the head unit to aftermarket and changing all the speakers to aftermarket as well, then it's pretty straightforward. You can use the existing speaker wires as long as you hook up everything correctly to your aftermarket head unit correctly. There is an audio signal from the OEM head unit that runs to the OEM bose amp behind the driver seat, so if you wanted to keep the same setup, you would run RCA cables from your aftermarket head unit to an aftermarket amplifier to an aftermarket subwoofer.
If you previously put in an aftermarket head unit and hooked it up to the OEM bose speakers, then you just need to remove the signal converter that you previously installed to convert the output for the bose speakers.
Old Oct 25, 2022 | 05:13 AM
iideadeyeii's Avatar
iideadeyeii
I brought my speakers wires through the center console to the amp in the back and hooked them up to the wires coming out of the factory amp. You could also re-wire them all directly from the HU
Old Oct 25, 2022 | 05:24 AM
D8V3's Avatar
D8V3
Ah ok! So just so I understand you correctly - there was an existing speaker cable going from the speaker in the door to the amp behind the seats. You snipped the wire in the door and put a new speaker in and you snipped the wire in the head unit harness and ran a wire to the location where the OEM amp was to effectively reuse that factory wire running from amp to door?
Old Oct 25, 2022 | 05:27 AM
iideadeyeii
I did not snip any wires in the doors(unless they had different connections from after-market speakers, but actually I ran RCA cables to an amp that sits in the factory subwoofer location and then ran wires to the trunk where the Bose amp is. The only wires you need to cut would be the wires on the plug coming from the Bose AMP, but yes I reused the factory wires going from the Bose amp to the speakers.
Old Oct 25, 2022 | 05:33 AM
D8V3's Avatar
D8V3
I did not snip any wires in the doors(unless they had different connections from after-market speakers, but actually I ran RCA cables to an amp that sits in the factory subwoofer location and then ran wires to the trunk where the Bose amp is. The only wires you need to cut would be the wires on the plug coming from the Bose HU, but yes I reused the factory wires going from the Bose amp to the speakers.
ah ok that makes more sense because the wires that are going to the speakers are already there. All I need to do is replace the amp in the factory location and reuse the oem speaker wire. Thank you
Old Oct 25, 2022 | 06:48 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Or there's this: https://my350z.com/forum/market/627218
Mfgr. Description here: https://catalog.pac-audio.com/catalo...ment/roem-nis2
Old Oct 25, 2022 | 11:23 AM
D8V3's Avatar
D8V3
Originally Posted by MicVelo
I already have something similar to this installed which is allowing my aftermarket HU to run the BOSE amps. A follow up question - if I simply bought 2 ohm speakers instead of 4 ohm would they work correctly with the stock BOSE 4 ch amp?
Old Oct 25, 2022 | 01:10 PM
Heel Til I Die
Has it actually been confirmed anywhere that the speakers actually are 2 ohm? I've seen conflicting reports where it's anywhere from a 1/2 ohm, 1 ohm, or 2 ohms.
I think the OEM bose amp is pretty underpowered based on the bose speakers. The magnets are pretty tiny. I doubt it has any type of decent power output. I would not wire anything that's aftermarket to the bose amp and expect it to sound decent.
Old Oct 26, 2022 | 02:11 AM
DarkZ03's Avatar
DarkZ03
Part of the problem from what I read was Bose sound profile stays with the amp? I removed the trunk amp from the bracket installed my own mini amp and just used all the existing wiring. Pretty seamless, new component speakers in the doors and woofer only for the rear. Then a powered sub in the factory location.
Old Oct 26, 2022 | 02:21 AM
D8V3's Avatar
D8V3
When you say "Sound profile" what do you mean? With regards to the amp in the trunk thats something I would be prepared to do but are the speaker wires not all wired into a big plug? and you have to figure out which wires are speaker wires and which are not?
Old Oct 26, 2022 | 03:03 AM
DarkZ03's Avatar
DarkZ03
Like a sound equalizer if that makes sense. Not sure as it's been a while. Yes I did cut the plug and spliced my amps harness into it, there are inputs, outputs, power, ground and signal just like any amp.
One thing to consider is most HU are 50x4 max while the mini amps will be 50x4 RMS.
Old Oct 26, 2022 | 03:40 AM
travlee's Avatar
travlee
Master
this is just me, back when i used to install stereos part time (never took home a check, just equipment.... the real reason i worked there) we would always run new wires for speakers.
Old Oct 26, 2022 | 07:14 AM
iideadeyeii
You can find the plug pin-out online.
ChrisMCagle
Jan 20, 2022 05:59 PM
liqalu04
Feb 14, 2016 01:16 PM
abretz89
Jan 30, 2012 04:00 PM
shinz
Aug 14, 2009 08:18 PM
Claybob86
Mar 25, 2008 10:45 AM
