Bad AM reception with aftermarket head unit
With the stock non-Bose headunit I was getting outstanding AM reception. There is a talk radio station a few hundred miles away that I always listen to. I could pick it up pretty fine with the stock head unit.
Last night I installed an Alpine head unit, and now my AM reception is worthless. I can't even hear a hint of that radio station. It's not even remotely there at all.
Anyone else experience this?
You'll never get good AM reception from an aftermarket stereo. The AM reception circuitry in them is worthless. Most brands focus on sound quality, visuals, and bells and whistles. AM reception is just included because its a standard feature that has been around forever. For best aftermarket AM results look into a Pioneer Super Tuner, as it has the strongest AM tuner that I have found.
A lot of people in this situation think changing the antenna will fix the problem, and sometimes stereo shops will sell amplified antennas to 'fix' the problem. Niether of these ideas have worked too well for me.
Kevin
For what it's worth, I fixed the problem.
It turns out that while wiring the harness I forgot to hook up the antenna amplifier power lead. (The 350Z uses an amplified antenna.) My Audi was the same way. If you do not hook up the power lead for the antenna amp, you'll get very poor reception.
I can now pick up my favorite AM talk radio station, even down here 200+ miles away from it. That's all I need in the AM band.
It turns out that while wiring the harness I forgot to hook up the antenna amplifier power lead. (The 350Z uses an amplified antenna.) My Audi was the same way. If you do not hook up the power lead for the antenna amp, you'll get very poor reception.I can now pick up my favorite AM talk radio station, even down here 200+ miles away from it. That's all I need in the AM band.
yep, when I saw the thread I knew that was your problem... alot of people don't know (at least those without the factory service manual) that there is an antenna amplifier located in hte hatch, clsoe to where teh antenna line comes into the car. Without this hooked up, your radio reception will be crappy.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
