Kenwood DDX 7015 DVD (Double Din) & System Started
Old May 15, 2004 | 07:01 AM
  #41
alpine's Avatar
alpine
Default Sorry for the delays... Here's some updates
View from rear to front, you can see the rear deck, amps, subs, and see the Head unit in the console, plus the lightingh affect on the amps.
Old May 15, 2004 | 07:02 AM
  #42
alpine's Avatar
alpine
Default Re: Sorry for the delays... Here's some updates
Both Amps, Side by Side, Neon Lit, Left long for visual affect
Old May 15, 2004 | 07:04 AM
  #43
alpine's Avatar
alpine
View from rear to front, subs & head unit visible
Old May 15, 2004 | 07:05 AM
  #44
alpine's Avatar
alpine
Rear deck view Subs, Amps, Support Platform view, final plate not yet installed:
Old May 15, 2004 | 07:07 AM
  #45
alpine's Avatar
alpine
4 Channel Amp Up close:
Mono Amp Up Close:
Old May 15, 2004 | 07:08 AM
  #46
alpine's Avatar
alpine
Long view of amps side by side
Old May 15, 2004 | 10:42 AM
  #47
BlueDragonZ's Avatar
BlueDragonZ
Thumbs up
Awesome set up.
Old May 16, 2004 | 07:36 AM
  #48
alpine's Avatar
alpine
Originally posted by BlueDragonZ
Awesome set up.
Thanks! I'm loving it, specially in traffic!
Also we're still playing with some stuff, more on that later.
Old May 16, 2004 | 09:18 AM
  #49
toykilla's Avatar
toykilla
Originally posted by BDeppe1316
Is there anyway to get DVD's to play without having to put your car in park?
yes, just attach the brake wire to ground you didnt here that from me
Old May 17, 2004 | 03:10 PM
  #50
RSX_2002's Avatar
RSX_2002
Sweet! It must be great gaving 2 screens, now you could navigate and watch movies at the same time!!!
Old May 17, 2004 | 11:01 PM
  #51
S2L's Avatar
S2L
Actually...thats a bad thing to do. Kenwood's have an internal 40 hr timer that starts as soon as it sees a ground. If you just ground the wire, eventually the unit will refuse to display the picture. You will still get audio, but no video. So you will need to take the wire off ground, wait an undisclosed amount of time, then reground it before it can work again. I have a kenwood Kvt 911dvd and what i did to get around this is to use the Ant. wire ( Solid blue wire) to pop a relay that takes the e-brake wire off ground every time i turn on my radio. The solid blue ant. wire only activates when you switch over to the radio mode. What this does is reset the internal timer. BTW..you didnt " here" this from me either..hehe
If anyone is interested in how i did it, drop me a PM.
Old May 18, 2004 | 04:56 AM
  #52
alpine's Avatar
alpine
I do not have 2 screens, at this time. Although they are coming.
If I had 2 video screens, though, with only this head unit, I would NOT be able to watch 2 different sources at the same time.
If I had a seperate video source, yes with the help of a external video switcher.
Old May 18, 2004 | 04:58 AM
  #53
alpine's Avatar
alpine
I was not aware of this timer, there are several ways to bypass playback locking, but I have no idea what any of you are talking about.
Old May 23, 2004 | 07:44 AM
  #54
alpine's Avatar
alpine
bump.
Old May 23, 2004 | 07:53 AM
  #55
alpine's Avatar
alpine
Default New Tires Nitto 555 245/40 & 275/40
I ended up getting my Nitto 555 Fron 245/40 and Rear 275/40.
Nitto Website for my Specific Tires
I got the street compund for durability, and I just came off Big Willow and they did VERY well.
I got my tires here at Chatsworth Tire, Check them out, good prices, great service, ask for Bob and tell them Joe with the Blue 350 Track Z sentchya, I've been dealing with them and the owner for years
Yes, they do let the rear out more than I would like, and if I didn't run VDC through nasty turns I would more than likely NOT toelrate it at all, however the rest of the time these tires rock once they are at "temperature" and "desired pressure"
Now I need the suspension configuration to keep up with these tires.
Old May 23, 2004 | 08:00 AM
  #56
Ahsmo's Avatar
Ahsmo
Imakecopies
anyone ever put this thing in that little pouch above the stock location?
Old May 23, 2004 | 08:40 AM
  #57
alpine's Avatar
alpine
This thing (kenwood ddx 7015) will not "fit" in the "stock" location as it is intended to occupy the space allowed for "stocK" double din OEM stereo systems.
If you want the screen to be there, there are some screens that will fit in there however it will be the screen only, and you will still need to install something in place of the stock stereo with a fit kit.
I've been very happy with the position of my screen. I used to have the kenwood 911dvd, which you can see from some of my previous pics.
it placed the screen higher, but when i don't want outsiders to know it's there is was much more visible, than the 7015.
let me know and I could find a configuration of something that will do what you are asking.
Old May 23, 2004 | 07:00 PM
  #58
SIX's Avatar
SIX
You indicated that you were going to hook up a rear camera. Does the Kenwood DDX 7015 support that option? If so, I would like to know how and where u plan on puting the camera. Do you have a specfic cammera in mind?
I plan on getting the same setup only I have the JL stealthbox and Jl500/1 amp awaiting this head unit. THx
Old May 23, 2004 | 07:16 PM
  #59
djkern's Avatar
djkern
i know someone who had this in the stock navigation location (the pocket was slightly modified....but not a serious project). he took it all out cause the stereo ended up giving him problems. he now has all alpine stuff...said his stuff is much better when it comes to precise tuning.
i like the looks of yours....i would just go with jl audio subs.
Old May 24, 2004 | 05:08 PM
  #60
alpine's Avatar
alpine
This unit takes "video" input, so if that is a rear-view camera or other, and you setup the unit to "auto" switch to video source, and that switch is your reverse to your rear view, yes it will work.
I don't have a specifc camera in mind as of yet, there are dozens out there, all you have to decide is where you DONT want the camera to go, and find out how much it's going to cost to put it where YOU want it.
I can come back with some ideas if you like
