Kenwood DDX 7015 DVD (Double Din) & System Started
Use the factory radio metal mounts as you described and a double din dash kit.
On the dash kit you will only need the double din face plate it will hook to the metal mounts. It looks real clean when done. If you like I can post a pic on mine
Yes you can do everything with the stock supplies, the trick is in the installation of the mount.
You can set it a little further down and back than what is "directed" you do have to make your own custom holes, but that will make it fit better.
So far mine is one of the best installs I've seen, and everyon that has seen it thinks it's a custom fitment kit.
You can make it nicer if you go with a custom hand made job, but for the slight improvement it will give you, it hasn't been necessary in my mind, or at the shop at Mobile Connection in San Fernando.
Not the worst thing in the world, you can get replacement parts from Kenwood..... Also I am looking at upgrading mine to the newer version, maybe If I make arrangement for that in the next few days, you can use my parts?
Look at this one for 600 bucks and it has a tv tuner on top of that!
http://dynamixcomputers.com/dynamix_700dx.html
Originally Posted by rx7/350z
i meant the factory z mounts . not kenwood parts. do i need those to metal plates that secured the factrory radio in place????
I have a feeling the answer is no.... I don't think you need that parts that came with the stock stereo....
I will be doing some work on the audio system and appearance by the end of this month.
Replacing the head unit with the next model, more screen, less buttons, plus FULL BLUETOOTH control of my phone(s)!
Carbon Fiber "beauty plate" for the rear deck.
Umm.....
Umm.....
