Gauges Cluster Removal...
Old Mar 18, 2004 | 01:20 PM
MadneZz's Avatar
MadneZz
Default Gauges Cluster Removal...
Anyone know how to remove the gauges cluster?
Thanks
HL
Old Mar 18, 2004 | 03:26 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Check out this thread over at 350Zfrenzy.com
Our old pal Scafremon does a really nice job on this:
http://www.350zfrenzy.com/forum/view...center_console
Old Mar 22, 2004 | 08:37 AM
MadneZz's Avatar
MadneZz
Thanks,
But I was looking more at the main cluster. RPM/Speed.. etc
Old Mar 23, 2004 | 05:09 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I don't think you can remove them independantly. If you look in the last pic in the dash removal, you can see how the three gauges share the one green circuit board. All you have to do from there is remove the screws that hold that on and they should come out.
Old Mar 25, 2004 | 10:08 AM
narkotic's Avatar
narkotic
RPM/Speed... He means the gauge cluster above the steering wheel.
Old Mar 25, 2004 | 03:34 PM
MadneZz's Avatar
MadneZz
Exactly what I wanted to removed.
Anyclue? anyone?
Old Mar 26, 2004 | 06:06 AM
SmO69's Avatar
SmO69
Yeah I was wondering that too... If you do get it open, let me know if you can re-do the gauges with white faces.
Old Mar 26, 2004 | 06:20 AM
daking350's Avatar
daking350
I saw Andrew from Smithstown remove it, it comes off in one big peice from the steering column..
Old Mar 26, 2004 | 07:22 AM
MadneZz's Avatar
MadneZz
Yeah,
I'm trying to get the gauges out, measure it, and redesign.
Old May 8, 2004 | 03:11 PM
ChrisMCagle's Avatar
ChrisMCagle
bump
Old May 8, 2004 | 11:46 PM
alphared's Avatar
alphared
You just have to take the steering column panels off.
The bottom has 4 screws (release the steering column adjuster to get to the 4th screw)
Remove the plastic Ring on the Key-slot and pull the bottom panel off
Now you can see the bolts holding the top panel (and the Combination Meters) Don't remember how many, but you'll know when you see it. Think it was four of them.
To remove it, you have to push the Steering wheel all the way down so that the panel will clear the dash. Lift up and unplug the meter.
Simple, should just take you few minutes to do.
Old May 9, 2004 | 04:10 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Oh, now I get it. I have never heard the SPEEDOMETER and the TACHMOMETER called a "gauge cluster" before.
Old May 10, 2004 | 07:52 AM
MadneZz's Avatar
MadneZz
My bad, I'm not sure what to call the entire thing..
I aint trying to take one or the other of...
But thanks
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
Calinismo350z
Sep 14, 2015 04:04 PM
